Old 01-28-2020, 07:57 PM   #1
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Dorman 902-310 Radiator Fan Relay Kit HZ setting
Connected the fan relay kit to a set of stock ls1 Camaro fan. when the PWM wire is connected, the fan motor makes an unusual noise, like an electrical signal noise, but no moment. I'm sure its a HZ hertz setting. if i ground the signal wire, it goes full speed. So it seems the relay is operating properly, just not the signal no jiving.
stock L83 is 100hz . Instead of trying a bunch of ranges, I figured i should post up and ask the mass'.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-01-2020, 11:29 PM   #2
87chevy.com
Re: Dorman 902-310 Radiator Fan Relay Kit HZ setting
I'm thinking this thing is just a dud, when grounding the signal wire, it was not full speed as i thought. its maybe 1/2 speed by the sound of the roaring noise of the fan noise. May warranty this unit, at this point I'm not sure
I did set the ecu to gen5 ecu fan setting to pwm_electric and 128hz per notes in hptuners and nada. noted that when turning on fan relay 1, it activated it. but it activated it at the original observed speed, 1/2-ish.
clint
