Old 02-02-2020, 12:41 AM   #1
724wdcopper
graphic designer
724wdcopper's Avatar
What goes here?
Electrical plug pointing at an empty hole in the heater core cover in the engine bay, what is supposed to be here? 1984 Chevy 3/4 ton 4x4
724wdcopper is offline   Reply With Quote
Old 02-02-2020, 02:51 AM   #2
mongocanfly
mongocanfly's Avatar
Re: What goes here?
blower motor resistor....https://www.americanclassic.com/1973...SABEgJLy_D_BwE
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-02-2020, 02:23 PM   #3
724wdcopper
graphic designer
Re: What goes here?
Awesome! Thanks!
Old 02-02-2020, 03:08 PM   #4
kipps
Re: What goes here?
Mongocanfly, can you explain a little more?
If the resistor is missing, do you only have high speed on the blower?
Is this literally just wiring a resistor in series with the motor to slow it down? Seems a little crude, but I guess it's cheaper than building multiple windings into that motor.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 02-02-2020, 03:33 PM   #5
Bigdually
Re: What goes here?
Typically yes, only high speed will work without the resistor because high on the switch is just sending full power to the motor. The lower settings have resistance in line for the lower speeds. It's in the cool air ducting to keep the resistor from overheating. Same principle used yet today on a lot of vehicles.
2.5 Ton Pickup Build:
1989 GMC 6000 Pickup/Toy Conversion
Bigdually is offline   Reply With Quote
Old 02-02-2020, 05:19 PM   #6
mongocanfly
Re: What goes here?
Big d got it covered kipps...one speed only
Mongo...aka Greg
RIP Dad
RIP Jesse
