Old 02-06-2020, 08:49 AM   #1
jmader
jmader's Avatar
Courtesy and Dome Light Wiring
I have read several thread on this and can not find the info I need. I'm installing a new AAW harness and when I plug in their connectors the dome and courtesy lights come on and I can't get them to turn off. I am not using door jamb switches just the headlight switch. I understand the white wire is a switched ground run through the headlight switch. I thought maybe my headlight switch was bad so I unplugged the harness from it but the lights still dont turn off.
My electrical knowledge is limited so forgive me if I'm being stupid here. My thinking is the the circuit is grounded somewhere and that's the reason why they won't turn off? Any help would be greatly appreciated.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 02-06-2020, 03:42 PM   #2
67ChevroletDude
67ChevroletDude's Avatar
Re: Courtesy and Dome Light Wiring
You are on the right path, the dome light is hot all the time and has a switched ground that runs to the door jamb/headlight switch and once the switch knob is turned all the way counterclockwise it completes the circuit. I would verify with a multi-meter that both wires are functioning as they should. From what you describe, the white wire is being grounded somewhere it shouldn't be making the light stay on even when the harness is unplugged from the switch.
This post below is very informative:
https://67-72chevytrucks.com/vboard/...d.php?t=611743
67ChevroletDude is offline   Reply With Quote
Old 02-06-2020, 06:47 PM   #3
jmader
jmader's Avatar
Thanks for the info. It’s good to know my thinking is correct
1967 Chevy SWB K10
Build thread-
