What if??
I take the front coil springs and rear leafs out of a half ton and put them in my 3/4 ton, will that give my truck the same ride height of a half ton? Is that the only thing that makes the ride height higher on my 3/4? Will there be any problem with doing this, driveshaft angle,etc? Thanks for any input.
Nobody? Any ideas on where I could find out for sure on this? Thanks
ndchevyman
I think that the a-frames on the 3/4 ton's are different from the 1/2 ton's. Some of the 1/2 tons had heavier springs that could have been ordered as an option from the factory. Sounds like it may be worth a try. You could always ask some of the specialist like earlyclassic If you do not get any response.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
Fabricate till you "puke"
I asked my little bro "what if".....he said what if toads had wings? I said "dunno".....he said they woudnt have to bump their @sses on the ground all the time
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
