Bleeding new brake system without an engine- need to wait?
Ive finally completed the install and i wanted to test for leaks and thought to bleed the brakes. I may be premature, does the engine have to be running to do this? Just to test for leaks? I havent installed the engine and was hoping to test for leaks first in the brake system.
I bought the plug for the prop valve and replaced the sensor with it. Ive got a bleeder kit also ready to start, just wasnt sure what I should/shouldnt do next. |
![]() Join Date: Feb 2014
Re: Bleeding new brake system without an engine- need to wait?
No bleed away if you have power brakes hook a shop vac up to test pedal
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
Moderator
![]() ![]() Join Date: Aug 2011
Bleed it.
Thanks guys for the quick replies, I actually dont even have the brake pedal installed yet. I'll hook that up first, been putting it off since the interior hasnt been covered yet with noise reducer mat stuff.
Moderator
![]() Join Date: Dec 2012
You don't even need a pedal, you can push in the back of the master. Even easier, gravity bleed it, it's full of air. Let the gravity do the work for you...
Moderator
That's what I did first is gravity bleed. Then used the pedal to check everything after. Went much smoother that way.
![]() Join Date: Oct 2006
X2 on gravity bleeding .
Make sure you bench bleed the master cylinder first before you bleed the rest if the system.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#8 | |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
#9 | |
https://www.amazon.com/Bestauto-Pneu.../dp/B07TMYSSN7
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
That will do way better that the tinker toy I used. I went cheap after having to buy the expensive flaring tool that did perfect by the way...no leaks!!
#11 | |
Bench bleeding with a syringe is the latest greatest way to do a master cylinder.
https://www.youtube.com/watch?v=USdtwqju4GY |
I’ve installed Speed Bleeders on three of my vehicles. Makes it a one person job. No complaints. They make it very easy to flush the entire system with new fluid as well.
'66 Custom Cab BBW SWB Fleetside 327/TH350 Factory A/C ‘96 Dodge Ram 2500 Laramie SLT Club Cab 4X4 8’ bed V10/47RE |
![]() Join Date: Apr 2011
#15 |
Duplicate post
#16 |
Front disc, rear drum???
If you have all drum or just rear drum, make sure the shoes are adjusted, and can even be adjusted a little tight, before bleeding. I also gravity bleed to start. |
#17 |
Now those are cool. Kinda expensive but I guess you could use and remove them for use on other vehicles.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
