Old 01-28-2020, 10:45 PM   #1
focusedontheprize
focusedontheprize's Avatar
Rear bumper bracket holes
I am currently fixing the rear frame rails on my ‘88 V30. I noticed that I have two sets of rear bumper bracket holes (1 1/4” apart) for my sport bumper. Could anyone recommend which set I should be using? I trimmed the rear frame rail, but can add material back if I should be using the front set. Thanks.
focusedontheprize is offline   Reply With Quote
Old 01-29-2020, 09:46 PM   #2
focusedontheprize
Re: Rear bumper bracket holes
Anyone able to help with this?
Old 01-29-2020, 10:19 PM   #3
RUN GMC
RUN GMC's Avatar
In this video I remember the fabricator talking about two sets of holes and which ones to use according to year......good info that might can help you......
https://www.youtube.com/watch?v=AvfLJ0m0GE8
RUN GMC is offline   Reply With Quote
Old 01-30-2020, 11:33 PM   #4
focusedontheprize
Thank you for this. I will have to check the channel and video out.
Old 02-09-2020, 07:16 PM   #5
focusedontheprize
Thanks again for sending this link. Unfortunately in this video they cut out the forward bolt holes that are used for the tow hitch (which I am using).
Can anyone provide a measurement from the rear edge of the frame rail to their bolt holes?
Old 02-16-2020, 02:11 PM   #6
SCOTI
SCOTI's Avatar
I got some pics for you from my dually. I added some text to help w/the numbers. 1, 2, & 3 are the bolts that retain the inner & outer brackets on mine.
#3 is approx. 5" from the edge of the frame rail & only goes through the last hole on the inner/longer bracket.
#2 is approx. 1.5" from the edge of the frame rail.
#1 & #2 go through both inner & outer brackets.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-20-2020, 09:43 AM   #7
focusedontheprize
Thank you very much SCOTI! Neither of the set of holes reflect those dimensions, so I am going to plug weld them and probably have to start fresh. I appreciate the information.
