02-17-2020, 10:06 AM | #1 |
swb frames
Do the panels share the same frame with the swb trucks?
02-17-2020, 11:04 AM | #2 |
Moderator
Re: swb frames
Panels (at least in 64) came in C14, K14 which are 1/2 ton - 115 wheel base. C36 which are 1 ton and C365 which are 3/4 ton - 133 inch wheel base.
Not to be confused with the suburban carryall panel door models C14 and K14, or the suburban carryall tailgate doors. See? I have lucid moments. I download the info from the GM Heritage center, you can also. Or get a 64 from here - https://app.box.com/s/r3ix7xdijprl91ho65fv9a8q5w34tbfi
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 02-17-2020 at 11:15 AM. |
02-18-2020, 05:52 PM | #3 |
Re: swb frames
Thanks , I have a 1965 115" wheel base 2WD. I'm going to put a K10 frame under it which leaves a frame available. Curious to see what it will fit?
02-18-2020, 05:54 PM | #4 |
Moderator
Re: swb frames
02-19-2020, 08:39 AM | #5 |
Re: swb frames
Guess I need to rephrase the question. The original 1965 panel frame , would a 1965 truck cab and bed bolt right on it ?
02-19-2020, 09:16 PM | #6 |
Re: swb frames
No, although they share the wheelbase(115”) the rear of the frame is totally different
Posted via Mobile Device |
02-20-2020, 08:13 AM | #7 |
Re: swb frames
Thanks for the response
02-21-2020, 08:57 AM | #8 |
Moderator
Re: swb frames
Here is a build thread page that shows the chassis being worked on. I don't know what if anything is different I cant tell. - https://67-72chevytrucks.com/vboard/...=735403&page=2
02-22-2020, 09:32 AM | #9 |
Re: swb frames
Thanks for the link , great info . I like pictures !!!
