Old 02-15-2020, 05:57 PM   #1
msg
Bleeding new brake system without an engine- need to wait?
Ive finally completed the install and i wanted to test for leaks and thought to bleed the brakes. I may be premature, does the engine have to be running to do this? Just to test for leaks? I havent installed the engine and was hoping to test for leaks first in the brake system.
I bought the plug for the prop valve and replaced the sensor with it. Ive got a bleeder kit also ready to start, just wasnt sure what I should/shouldnt do next.
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 02-15-2020, 06:08 PM   #2
nsb29
nsb29's Avatar
Re: Bleeding new brake system without an engine- need to wait?
No bleed away if you have power brakes hook a shop vac up to test pedal
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 02-15-2020, 06:11 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Bleed it.
Old 02-15-2020, 06:19 PM   #4
msg
Thanks guys for the quick replies, I actually dont even have the brake pedal installed yet. I'll hook that up first, been putting it off since the interior hasnt been covered yet with noise reducer mat stuff.
Old 02-15-2020, 09:54 PM   #5
jayoldschool
Moderator
You don't even need a pedal, you can push in the back of the master. Even easier, gravity bleed it, it's full of air. Let the gravity do the work for you...
jayoldschool is offline   Reply With Quote
Old 02-16-2020, 09:43 AM   #6
The Rocknrod
Moderator
That's what I did first is gravity bleed. Then used the pedal to check everything after. Went much smoother that way.
Old 02-16-2020, 06:21 PM   #7
slepysal
slepysal's Avatar
X2 on gravity bleeding .
Make sure you bench bleed the master cylinder first before you bleed the rest if the system.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-17-2020, 11:35 PM   #8
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
That right there is all it takes...and a little patience until all them air bubbles stop. I'm beyond that calling up from underneath with responses, "Up, up, down, down", rinse and repeat.
~Steven
Simi Valley, CA
Old 02-18-2020, 12:56 AM   #9
Jake1971
Jake1971's Avatar
After decades of the two person brake bleeding I finally bought a pressurized brake bleeder kit similar to the one I used in the Army Motor Pool for about $110 found it on Amazon.
https://www.amazon.com/Bestauto-Pneu.../dp/B07TMYSSN7
1971 Bone Stock C10 project "Jake"
1997 Sierra SLT factory short bed "Silver Bullet"
Jake1971 is offline   Reply With Quote
Old 02-18-2020, 10:20 AM   #10
msg
That will do way better that the tinker toy I used. I went cheap after having to buy the expensive flaring tool that did perfect by the way...no leaks!!
Old 02-18-2020, 12:20 PM   #11
Steeveedee
Steeveedee's Avatar
Yeah, I oughtta get one of those. I had access to one when I worked as a mechanic, but after graduating uni in '83, I lost that use.
~Steven
Simi Valley, CA
Old 02-18-2020, 02:49 PM   #12
bigmoe
bigmoe's Avatar
Bench bleeding with a syringe is the latest greatest way to do a master cylinder.
https://www.youtube.com/watch?v=USdtwqju4GY
bigmoe is offline   Reply With Quote
Old 03-18-2020, 09:20 AM   #13
Ronster66
I’ve installed Speed Bleeders on three of my vehicles. Makes it a one person job. No complaints. They make it very easy to flush the entire system with new fluid as well.
'66 Custom Cab BBW SWB Fleetside 327/TH350 Factory A/C
‘96 Dodge Ram 2500 Laramie SLT Club Cab 4X4 8’ bed V10/47RE
Ronster66 is offline   Reply With Quote
Old 03-19-2020, 05:32 PM   #14
'65 chevy lover
Good idea, I would have never thought to use a vacuum! You learn something new every day.
'65 chevy lover is offline   Reply With Quote
Old 03-19-2020, 05:35 PM   #15
'65 chevy lover
Duplicate post
Old 03-20-2020, 01:30 PM   #16
68Gold/white
Front disc, rear drum???
If you have all drum or just rear drum, make sure the shoes are adjusted, and can even be adjusted a little tight, before bleeding.
I also gravity bleed to start.
68Gold/white is offline   Reply With Quote
Old 03-20-2020, 01:47 PM   #17
bigmoe
bigmoe's Avatar
Now those are cool. Kinda expensive but I guess you could use and remove them for use on other vehicles.
