#526 |
Re: Used Parts Build
That exhaust wouldn't work so good here in PA. They changed the law last year so our exhaust has to exit behind the rear wheels... even on a truck. It used to have to exit behind the passenger compartment. I have to extend the exhaust on both of my trucks.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#527 |
I doubt this is legal but there isn't any inspection for 75 and back.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#528 |
#529 |
While looking at my old welds on this exhaust I wasn't really happy with them. I spent some time playing with a few scrap pieces using different cups, settings, and filler rod diameters. I think it was worth the time spent.
![]() ![]() Everything back purged of course ![]() I might go back and redo some of my uglier welds. ![]() Then I stripped down the inside of my tailgate so I can get some primer on it before it rusted. Its a bit to beat up for me to try to fix all the dents. I'll figure something out later. ![]()
#530 |
Do you have a source for this? I'm looking to get my exhaust redone soon and this is the first time I've heard of this rule. Did a quick google search and couldn't find anything.
#531 |
![]() ![]() Join Date: Jul 2002
I no longer live in PA, but I heard that from someone else when I was home a few months ago (Pittsburgh area), BUT it may not be a statewide thing and just a local/county thing. Anything I find on-line is 2016 era and it is still legal as long as it is within the sound dB range. Check with a local inspection station, as they should have the latest
#532 |
Just my inspection guy.... who is pretty lenient. I know other people that have said the same that go to other inspection guys.
#533 |
Just a tip for everyone. You can get silicone plugs from amazon for a few bucks compared to hundreds for a proper back purge set up.
![]() Got my waste gate all welded in. ![]() Started filing a bunch of holes and sprayed a little bit of primer over the bare spots ![]()
#534 |
![]() ![]() Join Date: Aug 2013
Wow..
#535 |
Thanks Joe.
I guess this whole stay at home thing has some perks. I wanted to stop all the dirt and leaves that get into the cowl so I cut some filler pieces. ![]() I didn't want to weld them in so I made them removable and used the mount holes from the original screen that it came with. ![]() Done ![]() Finally started on the massive whole I cut in my floors...This has been a bit of a mental block for me since there was so much to do. I dove in yesterday and made some progress. I am going to try to get a lot of it done during the shelter in place thing. Sadly (or luckily) I am an essential worker and have to work through this whole time :/ ![]()
#536 |
Still working on the floors.
![]() ![]() ![]() Started to cut some stuff in. ![]() Broke out the bead roller cause why not ![]() Here's where I'm at. ![]() Its taking wayyyy longer than I want. I also realize that the front is going to be the hardest. I guess Ill figure it out as I go...
#537 |
Great skills.....
#538 |
Shaping large pieces has been a bit too hard to manage. I am breaking it up and doing it in chunks. Not what I wanted to do but progress none the less.
![]() ![]() Next piece ![]() Started making the top piece to fit up against the fire wall. This one has been a pain to fit. Its a pain climbing in and out up under the dash. ![]()
#539 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Great work man, looking good!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#540 |
Little by little
![]() One more welded in ![]() The last piece on the passenger side is going to be rough. There are a lot of angles and not sure how I plan to tackle it yet. I have half of the driver's side done. Might do that for a bit while I think through the more complex piece.
#541 |
After way too much time and effort I got the driver side done.
![]() Time to finish the passenger side before I climb underneath and check to see if I missed anything. Then grind everything smooth (since why not?) before paint and on to the next thing on my never ending list.
#542 |
Got the passenger side done this weekend. Here are some pics.
![]() Made a little access panel to connect the fuel lines ![]() ![]() Welded up ![]() And done ![]() Didn't get a pick of the last filler piece at the top though. Now its time to grind a bunch of it smooth and paint.
#543 |
Got all the final welding done and most of the welds cleaned up then started scuffing and wiping it all down
![]() Then painted the inside. The lighting really messed with the pic though. ![]() Pulled the engine and started prepping the underside. ![]() Got some paint on there. Need another coat then Ill move on to cleaning up and painting the firewall. ![]()
#544 |
Nice progress.
#545 |
Thumbs Up....
#546 |
nicely done
#547 |
I haven't checked this thread in several months. Glad to see you are still at it and making progress. Keep it up dude
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
#548 |
Thanks everyone. I have been chipping away at it with all my extra time since there is nothing going on around here.
Painted my firewall ![]() Brakes ![]() Started reassembling stuff ![]() Ran out of paint so I started running my brake lines. Here is a practice flare ![]() Hoping my brake lines don't look like crap when I am all done...
#549 |
No exciting photos but got a fair amount of work done. Ran my brake lines.
![]() Then tore the front end apart so I can grind off all the POR15 that I originally painted with and do it properly. ![]() Gotta do something with the ugly front of the frame I messed up on years ago. Still playing with some ideas.
#550 |
