Still Green but learning
Factory tach dash
Hey guys I got a lead on a factory tach dash I'm going to get for $225. Looks like a good deal, I may have to replace the bezel but that's no biggie oh, they're only like 40 bucks. Question is I converted to HEI last year with the kit in the link below. Anyone have any experience here is that tack going to work with this kit?
https://www.speedwaymotors.com/SBC-H...n=orderconfirm
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
Re: Factory tach dash
Here is a pic of the one I am getting, or another one in similar condition but with a choke bezel (will have to replace)
Old member
Shouldn't have any problems. I have 3 trucks that I have ran with factory tack's & HEI with out any problems.
My 71 is now all digital though. The other two though. ![]() 67 Ramp truck: https://www.youtube.com/watch?v=dECJMzvB0fE 68 Stepper: https://www.youtube.com/watch?v=5NILbgGjFKg&t=6s
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#4 | |
Awesome, thanks!
#5 | |
Not to step on Andy's reply...I have painted a couple bezels...chrome was scuffed on 1, and needed painted or replaced.
Old member
Yes my daughter's cluster, I used Wal mart Chrome paint around the gauges & outer rim. I then sprayed the black. I think it turned out nice. The LED's really helped it.
Thats fantastic, If he doesnt ship me the one with the choke hole I think I am going to do this. thanks to both of you.
@ Andy, the chrome spray inside instead of the muted green didnt give you to much glare?
#10 | |
Old member
![]() Quote:
Great, thanks again, and I love the horn button in that first video. very cool
![]() Join Date: Sep 2007
man that looks pretty!!
1967custom |
#13 | |
Old member
![]() Quote:
I have a question, I have a 67 C10 with the factory bezel gauge cluster, My two part question is since my factory one will be replaced with a factory setup that will have a tachometer and vacuum gauge, Should I use a tach filter ? (Bought the filter BTW) and will I run into any problems because now the new one doesn't have the factory choke and the wiper switch will be where moved to the where the choke was ?
#15 |
Pics
#16 |
![]() Join Date: Dec 2013
Andy4639
May I ask where you got the d321 shift indicator? I have a l65e and would like to get one like that. Thanks |
#17 | |
Old member
![]() Quote:
The tack should work fine but other's have had problems with them. I never have. The shifter indicator was installed by member Randy500 when he did the column for me. Here is a link that you can try though that sells them. ![]() https://www.classicparts.com/1971-72...0aAjj8EALw_wcB
#18 |
I actually bought two wiring harnesses, (why) because I didn't know what distributor I was going with, The HEI that's in my engine now or something else, Waiting on an engine to be built to replace my 307, Thanks for the info, Much appreciated.
#19 |
The Older Generation
I flipped the pictures and deleted your post about them being upside down. LockDoc
#20 |
So will I need a new wiring harness coming from a std. 3 hole dash to the full gauges? I knew I would need to wire up the tach and change the oil sending unit. but thought the other stuff (temp/DC) was plug and play.
#21 | |
Old member
![]() Quote:
Nope you don't have to buy a new harness but you will have to swap some of the wires in the cluster connector for it to work. The electrical sections has everything you need to know. ![]()
#22 |
#23 | |
I would try it without the filter first. You will have to extend the wires for the new wiper switch location as Andy mentioned in his reply above. LockDoc
