Junior Member
![]() Join Date: Jun 2003
kick panel vent gasket
Looking for recommendation of material to use for kick panel vent. I bought a gasket set through a vendor but the material doesn't seem right. Any recommendations?
![]() Join Date: Jun 2017
Re: kick panel vent gasket
you can but them from classic parts of america web site they are $3.99 a pair https://www.classicparts.com/
Junior Member
anew4961 have you used them? The ones I have bought don't seem to be comparable to the factory material.
Old member
I bought the whole vent flapper for the 68. I have also cut inner tubes up to use as the gasket and they seal better than the new ones do and they will not hang up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Dec 2013
I just bought some rubber sheet , This ebay seller has it cheap with free shipping and different thicknesses to suit your project , I used it for the flapper vents and as a vibration layer between my rear mounted fuel tank and the frame .
![]() https://www.ebay.com/itm/Neoprene-Ru...YAAOSwlgdaf89j
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
