Old 03-01-2020, 11:03 PM   #476
6t9camaro
6t9camaro's Avatar
Re: 67 C10 "Green Gobblin" straight from the field!
Heres a few pics of finishing up the underside of the hood with the hood hinge brackets.
Build
67 Green Gobblin
http://67-72chevytrucks.com/vboard/s...d.php?t=688755
6t9camaro is offline   Reply With Quote
Old 03-03-2020, 05:05 PM   #477
cornerstone
cornerstone's Avatar
You got a ton of work done in just 2 days... Looks great man.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-17-2020, 01:18 PM   #478
6t9camaro
6t9camaro's Avatar
I had a nice little pile of parts delivered early last week so I've been busy with a few things! I got my Vintage air heater, A mock up set of front tires since i can tell there to small already, and the best part my Hills rod and custom inner front fender wells showed up! ( I will do a full review and install pics of those later)
Build
67 Green Gobblin
Old 03-17-2020, 01:23 PM   #479
6t9camaro
6t9camaro's Avatar
First up heres a few pics of the Vintage air heater and install. Nice quality part and the fit was pretty good with the space behind the dash.
Build
67 Green Gobblin
Old 03-17-2020, 01:28 PM   #480
6t9camaro
6t9camaro's Avatar
I decided to run the heater core lines through the firewall beside the heater delete plate to keep it simple.
Build
67 Green Gobblin
Old 03-17-2020, 01:44 PM   #481
6t9camaro
6t9camaro's Avatar
Heres how I modified the heater controls to use the original control housing. I didn't really like the Vintage air controls and I definatly didn't want them hanging under the dash. I took the new unit apart then Painted the old housing black drilled three holes for the new knobs then put in a thin layer of rubber to hide everything behind the knobs.
Build
67 Green Gobblin
Old 03-17-2020, 01:47 PM   #482
6t9camaro
6t9camaro's Avatar
Installed switches/knobs then did the wiring on the backside and thats it! Turned out pretty clean I think!
Build
67 Green Gobblin
Old 03-17-2020, 02:21 PM   #483
KMC3420
KMC3420's Avatar
You are correct that control panel turned out awesome! Very clean.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 03-17-2020, 02:25 PM   #484
Kronald_70GMC
Kronald_70GMC's Avatar
Very cool. I like the subtle upgrade. Looks much better and era correct.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 03-17-2020, 06:37 PM   #485
cornerstone
Very slick. I like the flatness in finish the rubber background gives you..
Brian
Old 03-18-2020, 03:01 PM   #486
knomadd
knomadd's Avatar
Nice job on the heater control panel! Can't wait to see the rest of the parts go in!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-20-2020, 05:55 PM   #487
6t9camaro
6t9camaro's Avatar
Thanks guys!
Build
67 Green Gobblin
Old 03-20-2020, 06:33 PM   #488
6t9camaro
6t9camaro's Avatar
Heres a few pics of the low profile tires I ordered up. I ordered these after getting the specs from a truck that I thought looked pretty sweet! Unfortunately once I got these tires in my hands I realized they were way to low profile for me and never survive on our local roads. :wash:
They look cool but just won't work but I mocked them up anyway just to see and get an idea of what i will need for clearance once i start on the wheel tubs. Oh and the size is 245/30/22 for those who might be deciding on wheel sizes.
Build
67 Green Gobblin
Old 03-20-2020, 06:40 PM   #489
6t9camaro
6t9camaro's Avatar
Here are the tires mounted on the 22" transits. The first pic is a 265/40/22 (rear) vs the 245/30/22 (front). Then a few pics on the truck.
Build
67 Green Gobblin
Old 03-20-2020, 06:46 PM   #490
6t9camaro
6t9camaro's Avatar
So after seeing that I had to get them off and put the bigger rubber back on! I rough cut out the front fender so I could drop it a little more and temp put the caps on and it looks much better! Front tire is still to big but I've got the idea of what size to go now.
Build
67 Green Gobblin
Old 03-20-2020, 06:49 PM   #491
6t9camaro
6t9camaro's Avatar
Next up ( hopefully start this weekend) is the front hills rod and custom inner fenders.
Build
67 Green Gobblin
Old 03-22-2020, 07:29 PM   #492
68bowtie
68bowtie's Avatar
Lookin good
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 03-28-2020, 09:58 PM   #493
6t9camaro
6t9camaro's Avatar
Ok heres some updates on the front inner fender install. What a PITA this has been! First off the inner fenders are very rough cut and need a lot of trimming/fitting. Ive probably had these things in and out and fenders off at least 25-30 time each side!
I was told these were going to be trim to fit so I'm not really suprized but still a lot of work. Heres a few pics to start.
Build
67 Green Gobblin
Old 03-28-2020, 10:07 PM   #494
6t9camaro
6t9camaro's Avatar
I used the supplied templates to get an idea of how much to cut out but I ended cutting out a lot more but it was a good start.
Build
67 Green Gobblin
Old 03-28-2020, 10:15 PM   #495
6t9camaro
6t9camaro's Avatar
Once the fenders were off you can see some of the trimming to get the inner fenders into place on the truck.
Build
67 Green Gobblin
Old 03-28-2020, 10:17 PM   #496
6t9camaro
6t9camaro's Avatar
Its in!
Build
67 Green Gobblin
Old 03-28-2020, 10:27 PM   #497
6t9camaro
6t9camaro's Avatar
Next up was cutting out the inner fender. I was dreading this part but it had to be done. I also pulled the inner fender back out to trim around the shock and locate the inner bolt holes.
Build
67 Green Gobblin
Old 03-28-2020, 10:41 PM   #498
6t9camaro
6t9camaro's Avatar
So after about 2 full days on the pass side its together with the fender on and all mocked up! It's a tight fit everywhere but looks like it belongs in there.
Build
67 Green Gobblin
Old 03-28-2020, 10:43 PM   #499
6t9camaro
6t9camaro's Avatar
Next up is the drivers side and that should be fun with the steering shaft and brakes etc...
Build
67 Green Gobblin
Old 03-29-2020, 12:25 AM   #500
kxmotox247
kxmotox247's Avatar
Project looks great! I have those same inner fenders for my project. Not installed yet. They are REALLY heavy. I'm going to stay tuned for your driver's side.
kxmotox247 is offline   Reply With Quote
