Old 03-02-2020, 06:26 PM   #926
hambone61
hambone61's Avatar
Re: What did you do to your truck today part IV
About $400.00
hambone61 is offline   Reply With Quote
Old 03-02-2020, 07:46 PM   #927
CRoss
Finished removing rear springs and mounts today in order to put new drop springs on my ‘63 longbed. Problem is the bottom bolts on both trailing arms are stuck in there. Heads snapped off while trying to remove them. Looks like tomorrow I will be drilling them out.
CRoss is offline   Reply With Quote
Old 03-02-2020, 07:50 PM   #928
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by studeclunker View Post
what's the difference between a Fuel Cell and a Gas Tank?
From a quick GOOGLE search:
Safety fuel cells work just like the gas tank on your street car, but they are designed to prevent spilled fuel in the event of a racing incident. ... Fuel cells generally consist of three parts: The outer can or enclosure, the bladder, and the foam baffling. The fuel cell enclosure is typically made of steel or aluminum.
~Steven
Simi Valley, CA
Old 03-03-2020, 10:09 AM   #929
jchav62
1962 C-10
jchav62's Avatar
From what I've heard, and it could be wrong... a fuel cell is usually made for racing, it is not metal, usually plastic and has foam inside for baffling for hard accelerations. I'm sure there are probably more to it than that, but that's my $0.02...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-03-2020, 05:28 PM   #930
forestb
forestb's Avatar
Definition wise I don't know but i can tell you why I bought a tank to replace my cell.
1. the cell started to warp. The top started sagging inward and the bottom started bowing upward. Yes it was vented, and no, the straps were not to tight.
2. The sending unit did not go all the way to the bottom of the cell, so I never had a correct reading of how much fuel I had left.
3. It came with AN -8 fittings so I ran an -8 fuel line that I think has been causing all sorts of problems sense I installed it. I know I could just replace the line but I needed an excuse to replace the cell with a tank
4. I was constantly smelling gas around the cell.
If that doesn't convince you, would you like to buy a used jazz fuel cell?
forestb is offline   Reply With Quote
Old 03-10-2020, 05:20 PM   #931
forestb
forestb's Avatar
Installed a pol rear sway bar on my 62. The truck is Still up in the air so I have not tried it out yet
Old 03-12-2020, 05:05 PM   #932
studeclunker
studeclunker's Avatar
That sway-bar reminds me I need shocks on my own Kidney Bouncer.
I've been pulling my hair out trying to figure out why my battery isn't charging and staying away from hammers and large wrenches so I don't do anything I might seriously regret!
studeclunker is offline   Reply With Quote
Old 03-21-2020, 02:37 PM   #933
crewguy
Todays day of self isolation included installing the new front park lights on the GMC. The counterpart lenses come with rivets which are way bigger than originals, and don't look good installed...5/16" as apposed to the lense openings of 3/16"...you can see the difference in the picture before and after. I filed down the rivets by hand to fit. Drilled out the holes on the housing as the rivet stems are a little larger too. Used an oversized punch with the lenses placed on an anvil to gently splay the hollow core aluminum rivets. Thinking I might try a felt pen or paint to tone down the color of the aluminum heads...Were the originals brass or metal? Problem solved, and they look great
crewguy is offline   Reply With Quote
Old 03-21-2020, 03:36 PM   #934
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Got the bumper installed. And mocking up the tailgate.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-22-2020, 11:06 PM   #935
rustyrodknocker
More life hours into floors. I'm over it.
rustyrodknocker is offline   Reply With Quote
Old 03-23-2020, 12:09 PM   #936
norcalcap
Finally got the Vintage Air installed and charged. I didn't like the look of the plastic box. Built this carpeted cover to reduce the fan noise and attempt to improve the look. It didn't turn out quite like the idea in my head, but it did reduce the noise and is easy to install and remove. The back was left open for air flow, only sides, front, and bottom are covered.
norcalcap is offline   Reply With Quote
Old 03-23-2020, 12:20 PM   #937
LostMy65
LostMy65's Avatar
Most tinkering on these trucks is therapeutic for me. But, for some reason the patch panels seem like work to me.
Old 03-23-2020, 03:01 PM   #938
straight6chevyguy
straight6chevyguy's Avatar
Looks good!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 03-23-2020, 04:07 PM   #939
UK62LW
UK62LW's Avatar
Took a break from refitting the front suspension to throw on my 'new' Road Runner camper shell.
I'm thinking it needs a chop (lose half the height of the chicken light strip?) but I'll have to see it on its wheels to be sure..
Barney, in the UK
1962 Chevy C20
1974 Ford Econoline
1987 Peugeot 205 GTi
1991 Peugeot 205 GTi
UK62LW is offline   Reply With Quote
Old 03-23-2020, 07:49 PM   #940
forestb
forestb's Avatar
Did final install (Lord willing) of my new gas tank. Next run a fuel line.
Old 03-23-2020, 08:37 PM   #941
goatless
goatless's Avatar
Installed the hood I bought from a guy on OfferUp, only to find that the passenger-side is dented, and I'll probably have to remove it to try to bend it back
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 03-24-2020, 12:46 PM   #942
pdxhall
pdxhall's Avatar
I patched the passenger side cab corner.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 03-24-2020, 05:53 PM   #943
nhtc33d
Originally Posted by shortstep60 View Post
I built a clutch master cylinder bracket that bolts on the inside of 60 truck. I bought a 3/4 bore master cylinder from speedway motors and made it work very clean and simple. Might sale some on the parts side of the forum.
I would be interested in seeing this bracket.
My build link.. http://67-72chevytrucks.com/vboard/s...d.php?t=285353
nhtc33d is offline   Reply With Quote
Old 03-25-2020, 11:10 PM   #944
cwcarpenter98
cwcarpenter98's Avatar
I added some door switches and floor lamps to Frankentruck today. So much nicer being able to see when getting in or out of the truck at night
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-26-2020, 04:33 PM   #945
jbgroby
jbgroby's Avatar
I ordered a Summit Trans Jack to help with the transmission switch, made in China, you can almost see the hand sanitzer stains........ It went together very well with no missing parts, even though the box was torn in one corner. The base on the unit is very heavy duty, there are 1/2" bolts under to holds the footing agains the verticle part of the base as well. Although I'm only going to use it once, I split the cost with a buddy who will need it as well, the total was only $175.00 with shipping ($10.00 more due to weight).
We considered renting one for a week but that ran $81.00 so it was cheaper to simply buy it vs. having to pick it up & delivery back to the rental place.
jbgroby is offline   Reply With Quote
Old 03-26-2020, 05:02 PM   #946
goatless
goatless's Avatar
Probably a good move. Never know how long these 'simple' things end up taking.
MECHANIC: "ME"
Old 03-27-2020, 09:33 AM   #947
jbgroby
jbgroby's Avatar
Thats exactly what we were thinking.
Old 03-30-2020, 08:29 PM   #948
creep
Registered Loser
creep's Avatar
Finished up installing the Street Demon 750 on my 383.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 04-03-2020, 08:55 PM   #949
forestb
forestb's Avatar
Installed Russell an-6 fuel line today
It fired up and no leaks (so far). Have not gotten to drive it yet
Old 04-12-2020, 03:33 PM   #950
Chevy Fleetside
Chevy Fleetside's Avatar
A few weeks ago I went up with my son and put the rebuilt cross member back in the truck. The calipers would not fit and I remembered I had to do some grinding the last time I put drop spindles in one of my trucks. Went back up and got that all sorted out and was able to get the truck back on the ground. So right now I have a 3" drop in the front with stock springs in the rear. I am sure it will drop down more when I put the engine back it. I also have new springs in the front.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
