Old 03-03-2020, 06:43 AM   #1
MASTERBrian
Fuel line
1960 suburban with sbc350 with 4 barrel eddy, manual pump. Tank is Tanks, inc. 38 Chevy tank with fuel supply coming out of threaded port on lower rear of tank. Line from pump to carb is braided with an fittings to hard line at top of motor with eddy fuel filter then hard line to carb.
Due to a few changes, such as tank and not liking my main inline filter being up under frame rail in front of rear axle, it's time to rerun things. Im currently aluminum line off rear of tank and up and over to meet the steel line where factory setup was with original tank. I ran all new steel lines 3yrs ago, but couldn't get a bend to go through frame rail so split and installed inline filler there. It's been a PIA to get to to change and a source of leaks. I also don't like having the rubber line going from aluminum to steel, I had to replace all the rubber due to cracking in 3yrs. Not understanding that, maybe parts store had crap hose.
What's everyone using? Aluminum, is obviously super easy to work, but will it last? Thought about finding some steel coil to protect it, like is used on brake lines, where it passes through any questionable spots. I can once again try steel line. Friend has some sort of braided? line going from tank to throttle body on his ls motor. I worry about that if aluminum it's frowned on.
I do want to relocate main fuel filter and possibly install either a manual or electric fuel shutoff valve, so trying to figure that out as well. Two fold reason on valve, one, it'd make future filler replacement simple if under truck. Tired of wearing fuel, yes if rubber hose I can clamp, but trying to eliminate the rubber. Two, if parking outdoors for long I could shut fuel off to stop a thief from going far. Granted, unless electric, I'd have to crawl under to do....hmmm! Just a thought.
Looking for ideas, suggestions.
MASTERBrian is offline   Reply With Quote
Old 03-03-2020, 06:55 AM   #2
bsarts
bsarts's Avatar
Re: Fuel line
I don't see anything wrong with using aluminum, you'll just have to make sure that it is well protected from rubbing and vibration. I don't like the idea of going from steel to alum. and back again though, but that's just me.
bsarts is offline   Reply With Quote
Old 03-03-2020, 07:02 AM   #3
MASTERBrian
Re: Fuel line
I guess PTFE is possibly what's on friends truck. That's what I'm leaning towards for simplicity and hopefully no future problems, but still looking for feedback.
Old 03-03-2020, 09:39 AM   #4
PGSigns
PGSigns's Avatar
Re: Fuel line
The nickel copper line would be the way to go and hard line it. It can be bent and flaired easily and will never rust. With the amount of ethanol in todays fuels I would not use aluminum.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-03-2020, 10:04 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Fuel line
Originally Posted by PGSigns View Post
... I would not use aluminum.
Jimmy
Either would I.
Old 03-03-2020, 11:03 AM   #6
Duncan K
Re: Fuel line
I went with PTFE lines and AN fittings. Pretty straight forward to install, and easy to make changes if needed.
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 03-03-2020, 12:36 PM   #7
MASTERBrian
Re: Fuel line
I don't love going from one to other, but I needed a custom bend coming of the tank and the aluminum was easy to form and I figured I'd replace later and could be a good template.
Old 03-03-2020, 05:11 PM   #8
forestb
forestb's Avatar
Re: Fuel line
what brand did you get?
forestb is offline   Reply With Quote
Old 03-06-2020, 01:11 PM   #9
Corts60
Just here to tinker
Corts60's Avatar
Re: Fuel line
I second avoiding the aluminum lines...the ethanol might wreak havoc on them if the truck sits for periods of time. If it is a daily driver, maybe it would be ok. Also, if you go with annealed copper, don't directly connect to the aluminum tank as there most likely be some galvanic action happening there.
Just my thoughts.
Old 03-07-2020, 10:14 AM   #10
Duncan K
Re: Fuel line
I bought them through Hot Rod Fuel Hose
Www.hotrodfuelhose.com
66 GMC 910
Old 03-07-2020, 10:44 AM   #11
Rickysnickers
Rickysnickers's Avatar
Re: Fuel line
When I plumbed my truck, i used the Push Lok hose. Easy to route and will withstand the fuel pressure and different types of fuel.
Old 03-07-2020, 11:17 AM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Fuel line
How does aluminum fair with ethanol?
How will it it fair with e15 or maybe even e85?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
