Old 03-07-2020, 01:27 PM   #1
kens65fb
Rear End Swap
Looking to swap the old 6 lug rear in my 64, and convert to 5 lug.
What year rear end would be easiest, and best, for fitment of 18 or 20 inch wheels?
kens65fb is offline   Reply With Quote
Old 03-07-2020, 05:18 PM   #2
bigmoe
bigmoe's Avatar
Re: Rear End Swap
You can buy axles to convert your existing rear to 5 lug.
https://www.youtube.com/watch?v=lfpRaNWutVw
bigmoe is offline   Reply With Quote
Old 03-07-2020, 05:35 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Rear End Swap
Yep that's the easiest way to do it. Buy 31 spline Moser Axles, Posi 3rd member etc.
I think I bought it all from these guys: https://www.quickperformance.com/GM-...-12T_c_54.html
Old 03-07-2020, 11:05 PM   #4
Captainfab
60-66 Nut
Re: Rear End Swap
Keeping your original 12 bolt and converting it to 5 lug will give you more room for tire and wheel than changing to a '71+ differential which are wider.
Old 03-08-2020, 11:17 PM   #5
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: Rear End Swap
1971-1972 , C-10 Rear Axles will Directly Bolt up (Plug N play). Not only will you get 5x5 pattern also they Have the Bigger Drums (Finned)...
The Axles are Longer, if I Remember correctly 1 1/2 inch on each side.. I've had 24x9 Inch Rims and Yesterday I put Rallys with New Rubber on. 15x8 255/r60 Tires, No Problems..
If you can find one Get It.. My 2$.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 03-09-2020, 07:01 AM   #6
bigmoe
bigmoe's Avatar
Re: Rear End Swap
'71 and up are 1 1/2" wider in total, 3/4" per side.
Old 03-09-2020, 11:50 AM   #7
verdell
verdell's Avatar
Re: Rear End Swap
As mentioned earlier, swapping axles would be an easy alternative. Yukon and Motive Gear also makes their versions of these available at Summit.
verdell is offline   Reply With Quote
Old 03-09-2020, 11:05 PM   #8
gulfcoast66
64-66 CHEVY JUNKIE
Talking Re: Rear End Swap
Yeah I Figured somewhere in that Ballpark, It's Been over 10 years since I Swapped Rear Axles... Thanks for Clearing that up bigmoe..
