Old 03-12-2020, 04:22 PM   #1
Ehodg66
Door lock relay location
I bought my truck with the power door locks not working (not a deal breaker) and just now getting into the repair.
I've read that the door lock relay is located above the brake pedal. Does that mean mounted on the firewall? I found these 2 plugs and they look like the connectors for the relay that I've seen on the forum, but no relay.
I have a/c duct under the dash, is the relay behind the duct work? mounted to the backside of the dash?
I've also attached a pic of my fuse panel that shows a black relay at the top of the panel. Can someone identify that relay for me also?
thank you
Ehodg66 is offline   Reply With Quote
Old 03-12-2020, 11:04 PM   #2
1774btcrew
1774btcrew's Avatar
Re: Door lock relay location
It should be attached to the right side of your pedal assembly
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 03-13-2020, 12:20 PM   #3
Ehodg66
Just looked again and that relay is definitely not there. Minor detail..lol
Thanks 1774btcrew
Old 03-17-2020, 09:18 PM   #4
Pontiac1976
Pontiac1976's Avatar
https://www.ebay.ca/itm/1980-81-Cadi...5/222585272770
This should look like this for the relay
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-17-2020, 10:48 PM   #5
Big Moose
Check behind the driver door panel, that's where I found mine
Big Moose is offline   Reply With Quote
Old 03-20-2020, 09:11 AM   #6
Sabaka454
Sabaka454's Avatar
#2
Sabaka454 is offline   Reply With Quote
Old 03-20-2020, 09:29 AM   #7
Ehodg66
Thanks Sabaka454,
Mine is definitely not there. PO maybe didn't want to spend the money to replace it.
Do you know what the relay(?) is on top of the fuse block? Also, is that a disconnected seatbelt buzzer next to it?
thank you
Eric
Old 03-20-2020, 10:50 AM   #8
Pontiac1976
The one with the like grill on it is the seat buzzer, the one on the left think it your horn relay.
You make a short wiring harness to adapter to aftermarket Relays.
