#101 | |
Re: 68 GMC frame off build
It’s worth the effort, that’s for sure.
--------------------------------------------------------------- Jason. 68 GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 Last edited by YBNORML; 03-12-2020 at 09:15 PM. |
#102 |
Took some parts in for blasting yesterday. Got them back today.
I just love freshly blasted metal.
--------------------------------------------------------------- Jason. 68 GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#103 |
Can we just take a moment to appreciate how straight the Original GMC tailgate is!!!!!
It cam off of the purple/white parts truck. I was totally expecting it to be full of bondo.
#104 | |
![]() If you don't mind me asking, about how much did it cost to bast all the parts in the picture?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#105 | |
It really is, gates like this just don’t exist up here anymore. $300. Cdn. They also chemically stripped the tailgate before blasting, they were afraid of warping.
#106 |
Another piece of the puzzle arrived today. Tires will be here early next week, cant wait to see them up against the original yellow paint
#107 |
Nice choice!
#108 |
A little sneak peak of where shes gonna sit. Give or take an inch or so.
#109 |
Got some fresh pics from my buddy whos doing the cab repairs for me.
#110 |
A few more.
#111 | |
![]() Join Date: Aug 2018
I've spent one full day so far mocking up, trimming, elongating holes, cutting, welding, etc. on my repro bed assembly. I knew I would have to, so I'm not frustrated about it. We also have an original shortbed assembly that we will be taking apart and putting back together so I'm interested to see how the two assemblies compare.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
#112 | |
I also put together a shortbox from all aftermarket parts a few a years ago. It required a lot of hole stretching to fit. Especially where the back of the box bolts to the crossmember. When I re-assembled this one. The front is all from the same truck so I had no worries there. But the rear crossmember is from a different truck. Happily it just slid right in and bolted up clean. Sure makes for a more pleasurable assembly.
#113 |
Some more pics from today. Drivers side getting close.
#114 |
This might sound weird. But this is one my favourite things to see when a cab is repaired.
I absolutely hate it when the metal or body guys eliminate this seam. It just looks so proper to be there.
#115 |
I'm impressed at how well that cab corner fits!
#116 |
Me too! Probably better that fresh off the assembly line.
#117 |
My man is good at what he does
#118 |
So the driver side is done and tacked into place. He likes to do all the fab work and then burn everything in completely.
#119 |
And on to the passenger side. Which although it looked better it is actually a fair bit worse.
#120 |
And for the gross part.
I cleaned several mouse nests out of this thing when I first got it, but never found this one ![]() ![]() ![]() ![]()
#121 |
Picked the cab up on Friday. I honestly couldnt possibly be happier with the quality of work.
No filler has been applied anywhere. The cab corner seam was intentionally put under the trim.
#122 |
Pressure washed the interior, sanded the floor and primed it. Itll get some sound deadener before carpet.
I also sprayed the back of cab corners. I just used some rattle can that was mixed up to match the original 520 light yellow. Pretty good match to the non-sun faded paint on the back if the cab.
#123 |
How did I get this OLD!
![]() Join Date: Dec 2014
Robert sure does nice work.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
#124 |
Yup, hes got some serious skills.
Pretty awesome for a hobby body guy.
#125 |
Body all mocked up. With the exception of the tailgate.
