![]() ![]() ![]() Join Date: Jan 2018
Rag Joint Rebuild Question
So my dad and I are at odds over if I need to replace the bowtie of the rag joint. I think that the bowtie is fine, but my dad thinks that some of the splines have been worn off. The area in question is the right side of the bowtie. What do y'all think?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Who Changed This?
![]() Join Date: Jan 2013
Re: Rag Joint Rebuild Question
I'm a hard-headed old man who worked as a mechanical engineer for many years. I'd replace it, personally. It's probably OK. Probably is a word of little value when it comes to certain safety critical items like this.
Thank you for your input. If I can find out that the area in question is not ok with my part, I will replace it. If it came from the factory with that part not splined, then I think it will be ok for me to use it again
Got another pic. If there were splines on this part that had been wiped out from wear, would there still be remnants of the splines in the slot where the bolt rides on the steering gear shaft?
#5 | |
![]() Join Date: Dec 2009
and run like that all these years. Now you have a choice. Full contact of a new one that you can be the Quality control guy, or run that one and hope it does not spin on the shaft at anytime. Safety first! This is my 2 cents. ![]() .
It does look kind of worn on the one side which indicates the pinch bolt may have been loose. I think it would be OK with PS. With a mechanical box maybe you could get it to slip a tooth when maneuvering in a tight parking spot but not so likely if the bolt is tight.
The bolt was definitely tight. Once I got the bolt out, I spent at least 30 minutes wacking the box with a hammer and using a pry bar to get them disconnected. Took me awhile, but I finally got it apart
I did some more digging through the site and found this. This rag joint that member Praxiss454 rebuilt for his truck looks exactly like mine. No splines in the area I circled in red
http://67-72chevytrucks.com/vboard/s...1&postcount=31
You only have 1 dad. (taking care of my 91 year old dad with Alzheimer's now). Let him win every now and then, how much does that part cost? Just a thought?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
So they was made that way.
Learn something every day. There's a wealth of info here on the site. I just wonder what the replacement part looks like? .
#11 | ||
I found a replacement on Rockauto, but it does have splines completely around. The other places that offered them does not have a clear picture showing the splines. I think what I will do is put the rag joint back together with the rebuild kit that I already have so I can make it to the cruise in on Tuesday, then order the one from Rockauto for the extra splines, put it in, and have the rebuilt one as a backup Thanks y'all for the input!
I created several DIY pages that explain all aspects of a 1963-66 manual 3 speed steering column rebuild. You might find what you need here.
1963-66 Steering Column Rebuild Page All of the steering column pages can be found HERE.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#13 | |
I'm happy to report that I was able to get everything back together and that the truck drives so much better now Also, my dad and I had a great laugh today when I was trying to stick the forward most nut onto the steering box bolts and kept spinning it left instead of right because I was looking at it from the steering gear side. After struggling for a little bit, he finally asked "Are you turning it the right way?" ![]()
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 03-15-2020 at 09:29 PM. |
Who Changed This?
That is a how many years old truck!? I've never seen a steering coupling where the outer piece had no splines unless it was damaged. You can do what you want to do, and maybe there will be no consequence. People can do whatever they want. As an engineer, I could design a press fit, but would never ever have made a press fit where safety was involved. It would be either cross pins (if they didn't compromise the strength) or matching splines. YMMV
#15 |
![]() Join Date: Mar 2013
Interesting thread. Here is yet more interesting fact/ photos. I have had this NOS Saginaw steering coupling in my inventory of parts, just waiting to put on my 66. Never thought to look at it closely as it is NOS. Today I pulled it out to look it over, and much to my surprise! Well I will attach photos for all to see.
#16 | |
