Old 03-16-2020, 11:04 AM   #1
splehigh
splehigh's Avatar
1980 GMC Crew Cab Question. 81 Cab?
Hello everyone,
I recently bought a 1980 Crew cab 2500. According to the VIN it is an 80 crew cab 2500 but it has the newer 81-87 style cab and front clip. The slots in the cab for the hood hinges appear to be there from the factory. It also has the newer style 81-87 style dash.
So at this point I'm trying to figure out if someone swapped the vin tag or if its possible that it was a late production 80 that got the newer cab. I don't think that is possible but one could hope. Perhaps Keith Seymore could answer that.
The VIN is TCM24AB******
Any help is greatly appreciated. Thanks
splehigh is offline   Reply With Quote
Old 03-16-2020, 11:16 AM   #2
mongocanfly
mongocanfly's Avatar
Re: 1980 GMC Crew Cab Question. 81 Cab?
on my 81 chevy ,the blinker lights are in the bumper..is gmc is different ?..
how is the fit of the fender to the cab in the red circled area?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-16-2020, 12:27 PM   #3
sweetk30
sweetk30's Avatar
thats a 89-91 work truck style grill setup with 2 headlight .
81-82 only had turn signal/markers in the front bumper .
ether someone re-bodyed the truck or swapped a vin or gave you a bogus title . . .
and 1980 was about the change over year for the newer font style on the gauges for gm .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-16-2020, 12:34 PM   #4
My 81 GMC has the newer stuff on it too. It got in a fender bender with the first owner and they used an 85 for replacement parts I have the headlights/turn signals in the grill now and the later style bumper. I'd say someone did the same for yours either for looks and maybe a fender bender like mine. It is easy to swap over the radiator support and front bumper (or even whole front clip). 80 was a sort of changing year. I am not sure if 80 used the old style hinges or the later style hinges, but I know folks swap front clips out a lot with no issues. The wiring may not have even need changed or modified. I have since gone back to a 81 center grill, but left everything else the same.
Old 03-16-2020, 03:46 PM   #5
rod1701
rod1701's Avatar
80 truck. 90 front clip. If it came off another white fleet truck, may look pretty close to a factory job.
1979 C-10 LWB
rod1701 is offline   Reply With Quote
Old 03-16-2020, 06:01 PM   #6
splehigh
splehigh's Avatar
Well the VIN matches the title. I made sure of that before purchasing.
I'm thinking it was either a really good clip conversion or someone swapped the VIN from an 80 to an 89-91 cab.
Old 03-17-2020, 08:35 AM   #7
MJN
MJN's Avatar
Is the VIN plate held on with factory rosette style rivets? Besides the front clip the mirrors have been changed and are from a van. Looks like its had quite a bit of work. You can also make the 81 and newer dash pad work in the older cabs, so look there for any adaptations made to make it fit.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 03-17-2020, 12:35 PM   #8
splehigh
splehigh's Avatar
The vin tag does have the correct rosette rivets. I'm pretty sure those can be bought though.
I didn't notice the mirrors before.
I was looking at it again last night and realized it has the ECM behind the glove box. So it's definitley not an 80 cab.
Perhaps the year was wrong on the title?
Old 03-17-2020, 03:58 PM   #9
93M6Formula
You definitely have a mutt on your hands. That's an 89-91 Non-V22 grille and headlight bezels and everything else is definitely 81+. If it has an ECM in the dash, I feel like someone VIN swapped an 89-91 truck.
I think I would pull the dash pad and look for VIN tampering. If it truly has a 1980 VIN, the tag won't fit right under that dash because they are only 13 digit vs 17 digit on 1981+ vehicles.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4
1988 GTA Trans AM 305 TPI 700R4
1993 Formula Firebird LT1 T56
1995 GMC K2500 ECLB 6.5L 4L80E
1996 GMC K3500 CCLB LB7 6L90
93M6Formula is offline   Reply With Quote
Old 03-18-2020, 06:31 AM   #10
splehigh
splehigh's Avatar
Thanks. I'll check that out.
Well at least I didn't pay much for it and it has almost no rust. Even the inner rockers are rust free.
