03-20-2020, 07:28 PM | #1 |
Torque specs for engine and transmission?
Ive got a 66 c10 but the engine Im putting in is a 350 vortec L31 and I have a 700r4 transmission, but the 62, 66 shop manuals and assembly manuals I have wont cover it since they didnt have these in 66. Since the upgrade ventures into the later models I thought I would check here and see what resources you all recommend to get torque specs for what Im replacing and installing.
These are the torque specs I was hunting. flexplate to torque converter flexplate to crankshaft Bell housing to motor engine mount to motor engine mount to brace brace to frame |
03-20-2020, 08:11 PM | #2 |
Re: Torque specs for engine and transmission?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
03-20-2020, 08:23 PM | #3 |
Personaly have never torqued any of those.Just make sure they are tight but dont go crazy.
03-20-2020, 08:37 PM | #4 |
The only one I put a torque wrench on is flexplate to crankshaft. The others I torque with a liberal application of goodentite.
03-20-2020, 09:20 PM | #5 | |
Don't forget to use a little loctite on the flexplate bolts. |
03-20-2020, 09:58 PM | #6 | |
03-20-2020, 11:14 PM | #7 |
I really appreciate the feedback on this since Im a first timer and didn't want to make a mistake especially those that could be disastrous. If tight but not overly tight is the way then thats what I'll do.
On the flexplate to crankshaft then whats the spec I should use you think? And on the loctite I bought the blue medium tube. I had planned to use it and had gotten a negative reaction from others saying how ill regret it whenever I need to ever work the bolts that have it on them. I was going to use a small bit just to feel better but knowing it could make for a big pain if I need to back the bolts out. |
03-21-2020, 11:25 AM | #8 |
Medium thread locker and 60 lb-ft on the flexplate to crankshaft - it's in the table I linked to earlier. I've never put thread locker on torque converter bolts. Just get them tight. If you do use thread locker on those bolts, make sure you use the blue. If you use red you might never get them out, just because of how hard it is to get good torque on them.
03-21-2020, 02:35 PM | #9 | |
I Was A GM Master Technician for 30 years and I always torque everything that mattered you can tell the difference with comebacks.
I. Always Hard Great CSI Scores Even Z06 Vette That I Had to Repo The 3 RD Piston Ring did Like 20 Of those Oil Burning POS Never Had 1 Comeback Quote:
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
