Old 03-20-2020, 09:23 PM   #1
jchav62
1962 C-10
jchav62's Avatar
Vintage Air voltage drop
Hi all! Not too long ago i purchased a used vintage air setup from a fellow member. It's been installed for a while. I'm finally going to take it in for some r134 tomorrow. Anyhow, i just notice that when I turn the fan on, the voltage drops to just under 12 volts (aftermarket gauge) and the Gen light faintly comes on. With the multimeter, it still read about 14 volts at the battery, but about 11-12v at the fuse box. The higher the fan speed, the lower the volts. I have converted to an internally regulated alternator. Any ideas on what's causing this voltage drop?
Thanks... and wish everyone all the best during these crazy times.. stay healthy
JC62
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-21-2020, 02:46 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Vintage Air voltage drop
What is the amp rating of your alternator? Intalling my Vintage Air AC system was one of the reasons I went with a 160 amp alternator.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-21-2020, 03:02 PM   #3
sstock
sstock's Avatar
You have a large enough feed wire to your fan motor?
Feed wire size from battery to fuse panel?
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 03-22-2020, 03:11 PM   #4
jchav62
1962 C-10
jchav62's Avatar
I'll have to double check. I upgraded but i don't remember the expat amperage.
Joseph Chavez
Old 03-22-2020, 03:13 PM   #5
jchav62
1962 C-10
jchav62's Avatar
I put in a new under hood harness. Under the dash is still original wiring. Factory fan wiring.
Joseph Chavez
Old 03-22-2020, 10:33 PM   #6
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Ac Compressor Pulling To Many Amps, You need A 160 Amp Alternator
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 03-24-2020, 12:19 PM   #7
jchav62
1962 C-10
jchav62's Avatar
It's actually the heater/ac fan. It was doing it with just the heater, before I even put Freon in the system. Now that the system is charged and the compressor is cycling on and off, it doesn't drop the voltage.
I'll upgrade the alternator. thanks!
Joseph Chavez
Old 03-24-2020, 12:40 PM   #8
The Rocknrod
Moderator
The Rocknrod's Avatar
I think the compressor doesn't pull amps does it? It just grounds and engages the clutch. Is that correct? Unless a computer controlled vehicle has something else?
Old 03-24-2020, 12:41 PM   #9
sstock
sstock's Avatar
Before you buy another alternator, run a 12 guage jumper wire directly from the battery to the fan lead and check for voltage drop there. The fact that you still have the original fan motor feed wire sends alarm bells to me, just not big enough to carry the load. You know ohms law higher the resistance the more the voltage drop. Quick analogy, the wire from the fuse panel to the fan motor is like you are trying to pass a four lane road full of cars down a two lane street.
Old 03-25-2020, 02:56 PM   #10
jchav62
1962 C-10
jchav62's Avatar
That makes all kinds of sense! I'm definitely going to try that. Great idea...THANKS!
Joseph Chavez
Old 03-25-2020, 09:22 PM   #11
jayoldschool
Moderator
Rule out a loose/slipping alternator belt before worrying about anything else.
jayoldschool is offline   Reply With Quote
Old 03-25-2020, 10:42 PM   #12
69 C10 LWB
It sounds like you have a voltage drop or bad ground to the cab. If you still have 14 V at the battery your alternator is probably fine. If you had a voltage drop on the fan wire your fan would be slow but your voltmeter should not drop. It sounds like you may have a bad connection where the main power wire goes into the cab or possibly at the horn relay if you still pull cab power from there. Could also be a bad ground to the cab.
69 C10 LWB is offline   Reply With Quote
Old 03-31-2020, 12:59 PM   #13
jchav62
1962 C-10
jchav62's Avatar
I replaced the original wire from the fuse box to the fan switch with a 10ga wire. That seemed to do the trick. The voltage still drops with the fan on, but no lower 13v with the fan on. Around 12.5 on high. Thanks for all you input...
Stay safe! JC62
Joseph Chavez
