It followed me home?
Any lowered flatbed trucks?
Anyone have pictures of lowered flatbed trucks?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Re: Any lowered flatbed trucks?
My LWB Steel Flat bed is lowered by the body mounts 2 caravan mounted on rad-support from the K-frame mounts.
body mounts 4 Windstar mounted on cab from the K-frame mounts. drop is about 2-1/2" . This what did to GMC 1/2ton LWB steel flat bed.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
I can see this being a neat truck to own.
Are you doing a dually or a single rear wheel? Either way make the rounded hump over the tires. It looks much cleaner. |
i saw a tool box chevy that was dropped man it looked good too.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
