Old 03-25-2020, 04:23 PM   #301
Jesse49chevy
Jesse49chevy's Avatar
Re: Jesses' 48 PU
Originally Posted by dsraven View Post
If you have a compressor why not get a gravity help gun and spray bodyshop grade epoxy and high build etc. It would be cheaper and a better coverage than the spray bomb stuff. Especially when you start the high build. Easier to get a nice flow so less orange peel texture.
DS yes I have a compressor and paint guns, but being that I live in a subdivision and the HOA is itching to fine me, I don't have the space or proper area to spray. So I bought the aerosol stuff to take care of the small parts. I do plan on using epoxy, high build primer on the body.
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline   Reply With Quote
Old 03-25-2020, 04:25 PM   #302
Jesse49chevy
Re: Jesses' 48 PU
Originally Posted by Jason 56 View Post
Your truck is coming along nice. You’re doing a great job on all the mods!
Thanks Jason....
Semper Fi
Old 03-25-2020, 04:33 PM   #303
Jesse49chevy
Re: Jesses' 48 PU
I have a little blaster like that. works great. sure fills the coveralls pockets up quick though. haha.
curious what that black diamond media is and how it performs compared to sand. I use sand, works ok. thought maybe there is something better. does the black diamond leave a big profile?
Yea, think I'm still digging sand from areas I can't mention...lol.
The black diamond is a resin based product with a little bit of glass... I've never used sand as this stuff is cheaper ($5.00 a bag) and there is very little dust. I normally put a tarp or use it in a area where I can sweep it up, except this time. I'm sure it will kill my grass. Not sure what you mean by profile, but it cleans pretty well, doesn't heat up the metal as sand does...
Semper Fi
Old 03-25-2020, 04:35 PM   #304
Jesse49chevy
Re: Jesses' 48 PU
Off to the media blaster....long time coming didn't think I'd ever get to this point... Heck even my wife is getting excited....
Semper Fi
Old 03-25-2020, 05:34 PM   #305
8man
Re: Jesses' 48 PU
Big day! Hope you get it back quickly.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 03-26-2020, 03:55 AM   #306
dsraven
Re: Jesses' 48 PU
don't you love it when a plan comes together? seems like we do a bunch of work and it looks the same. then one day it just seems to shoot ahead.
by sandblast profile I meant roughness of the surface. some abrasives are pretty rough and leave actual visible high spots. if the high spots aren't sanded down before primer the primer can just sink into the low spots and the high spots (we're talking about using magnifyers to see this but you can feel it) will end up with no paint on them so they start to rust quickly. there are 2 types of blast media. cutting and non cutting. glass bead is an example of non cutting. it blasts the paint ertc off because it spins when it exits the nozzle and hits the work. that removes the product you want to remove but the spin has less effect on the metal when it hits bare steel or aluminum. aluminum oxide is a really common cutting abrasive, like I use in my little portable blaster. it removes paint etc pretty quick but leaves a taller profile, though, so the blasted part needs to be sanded prior to primer. sorta like the difference between fine sand paper and course sandpaper. fine paper could be primered over and the abrasive would be covered with the primer. if you sprayed the same amount of primer on the course paper there would be the peaks of the grit not covered by the primer. in my blast cabinet I use garnet because it doesn't turn to powder right away and lasts longer. the profile isn't as big as aluminum oxide but I sand stuff anyway afterwards. aluminum oxide is really hard so it leaves a bigger profile than sand. sand is softer, like a #4, and explodes on impact so has less profile than alum oxide, a number 9. silicone carbide, a number 9.5, is even harder than alum oxide. when blasting and not recycling the blast media sand works fine. a blast cabinet automatically recycles the blast media.
Old 03-26-2020, 02:50 PM   #307
dsraven
Re: Jesses' 48 PU
here is a pic that shows what I mean about profile. it's like sandpaper. that is using regular sand at a u blast place. you can see the pock marks if you look close enough. pics turned, sorry.
Old 03-26-2020, 10:13 PM   #308
Jesse49chevy
Re: Jesses' 48 PU
Hey DS, thanks for the explanation/lesson on sandblasting and media. Honestly, I did not realize there was so many details to it. I've used this media several times on both my blaster and cabinet I like the results and I don't feel the need to sand with finer grit afterwards. Here is a pic of the angle support, it's pretty smooth.
Semper Fi
Old 03-26-2020, 10:18 PM   #309
Jesse49chevy
Re: Jesses' 48 PU
Well I decided to do away with the old mustang fuel tank. It simply would not work with the LS engine without modifications, so I went with a TankersInc EFI tank, came with fuel pump, sending unit, hose and fittings. So I welded some 3/16 inch plat on the frame and went with 1.5 inch square tubing for the frame the tank will sit on.
Semper Fi
Old 03-26-2020, 10:19 PM   #310
Jesse49chevy
Re: Jesses' 48 PU
Tank is in.
Semper Fi
Old 03-26-2020, 10:21 PM   #311
Jesse49chevy
Re: Jesses' 48 PU
My plasma made it easy to cut out the exhaust pass through holes.
Semper Fi
Old 03-26-2020, 10:27 PM   #312
Jesse49chevy
Re: Jesses' 48 PU
Made a little jig/tool to cut close to perfect circles with the plasma. Took a one inch hole saw I had laying around. Welded a 1 inch flat bar, drilled a pilot hole 2 inches from center. After deciding where the exhaust would run through I Drilled a pilot hole, stuck a drill bit to hold the jig in place and Baamm! 4 inch circle cutouts... I will roll up some 3/16 metal tomorrow and weld them in.
Semper Fi
Old 03-27-2020, 01:03 AM   #313
dsraven
Re: Jesses' 48 PU
how do you get a 4 inch circle when you are using a 1 inch hole saw, 1 inch flat bar and marking 2 inches from center.
4
1
1
2
8
doesn't compute. then ad in the size of the pilot hole plus the 3/16 roll. what does that come out to again?
haha.
looks good, mr "I have a plasma cutter"...…..
Old 03-27-2020, 09:31 AM   #314
Jason 56
Re: Jesses' 48 PU
Great ingenuity... I’m adding that one to my bag of tricks!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 04-02-2020, 11:42 PM   #315
Jesse49chevy
Re: Jesses' 48 PU
Worked on the exhaust today.. ordered a 3" mandrel bend kit and 3" pipe.
Its tricky to get the cuts right, but with a little patience and determination... it can be done.
Not perfect but im happy with it, hoping to finish it up tomorrow.
Semper Fi
Old 04-03-2020, 08:50 AM   #316
8man
Re: Jesses' 48 PU
Looks good!
8man-aka Robert
Old 04-04-2020, 04:18 PM   #317
Jesse49chevy
Re: Jesses' 48 PU
Got the call Wednesday that it was ready. Had to wait until today to go pick it up.
Bad thing about media blast, you get to see everything!! So a few more patches and some body work needed.
Semper Fi
Old 04-04-2020, 04:19 PM   #318
Jesse49chevy
Re: Jesses' 48 PU
Semper Fi
Old 04-04-2020, 04:40 PM   #319
8man
Re: Jesses' 48 PU
Ready to go now!
8man-aka Robert
Old 04-13-2020, 09:58 AM   #320
Jesse49chevy
Re: Jesses' 48 PU
Not happy with the exhaust I did some research on a reliable source YOUTUBE. After watching some great videos. I discovered PIE CUTS. So I dragged out my band saw and cut plenty of pieces. Removed what I had previously installed and started over. Its alot of work, but im happy with it and feel its coming out better. Still not done, but meh.....
The band saw really makes things easier with nice straight cuts.
Semper Fi
Old 04-13-2020, 10:13 AM   #321
Jesse49chevy
Re: Jesses' 48 PU
9 degree Pie cuts... not apple..
Semper Fi
Old 04-13-2020, 10:14 AM   #322
Jesse49chevy
Re: Jesses' 48 PU
Semper Fi
Old 04-13-2020, 10:15 AM   #323
Jesse49chevy
Re: Jesses' 48 PU
One piece down ....
Semper Fi
Old 04-13-2020, 10:18 AM   #324
8man
Re: Jesses' 48 PU
Yep, those are nice cuts. Also a nice weld job.
8man-aka Robert
Old 04-13-2020, 10:19 AM   #325
Jesse49chevy
Re: Jesses' 48 PU
TIG welding is the way to go, but boy do I need practice and this is not the project for it. So MIG'd it. Not as clean and pretty but good hot spot welds all the way around ensured solid welds.
Almost done.
Semper Fi
