Old 03-29-2020, 11:00 AM   #1
BMCFAM4
Question Transmission Swap 66 C10
I have been working on a 66 C10 restoration for 4 years, I am finally at the point where I need to figure out my new transmission. The truck came from the factory with a 283 engine, 3 on the tree transmission and 3.73 12 bolt rear end. I think my transmission hump would be considered low profile. Do any of you folks know of an OD automatic or 5 speed swap that will fit in with the low profile hump?
BMCFAM4 is offline   Reply With Quote
Old 03-29-2020, 12:12 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Transmission Swap 66 C10
I have a low hump. I have a 350 engine and a 200R4 transmission set up that fits. I used the POL engines stands, with them you must trim back the upper frame rail a bit on each side. The trans cross-member is also from POL.
Old 03-29-2020, 12:41 PM   #3
pdxhall
pdxhall's Avatar
I'm running a 700r4 with a CPP trans cross member. fit with no issues with small hump.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 03-29-2020, 04:50 PM   #4
SS317
SS317's Avatar
I have a 350 tied to a 700R4 with a low hump. Best upgrade I've done to the truck.
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
Old 03-29-2020, 06:56 PM   #5
jocko
jocko's Avatar
swapped a T5 into my 66 C10 283/3OTT/3.73, no regrets other than the fact that I sold the truck... http://67-72chevytrucks.com/vboard/s...d.php?t=482069
Old 03-29-2020, 10:39 PM   #6
BMCFAM4
Thanks for the info.
Old 03-30-2020, 12:59 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I had the same question.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
66 c10, swap, trans
