#1126 |
Re: What did you do to your truck today.The 3rd chapter
Removed the duel exhaust from the headers back. I was able to get one side replaced before i stopped for the day. I got tired of banging my head under the truck. LOL.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350 1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job 1953 Buick Special. GM 355. Just a good smooth engine. |
#1127 |
Old member
New Tach and speed warning installed in the cluster going in the Ramp truck tomorrow.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#1128 |
![]() Join Date: Dec 2012
Finally roller status. Still working through torqueing the front control arm shafts to allow more range of motion. I torqued them in the air versus loaded on the ground. Big mental stepping stone for me. The wheels are just roller wheels I borrowed from a buddy, but I like the wide look.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
#1129 |
KMC,
Looking good. I was just south of you in Marshall yesterday. The classic, slotted aluminum wheel is like a pair of jeans. Never out of style totally. I want to hear more about the exhaust cut outs in the cross member.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#1130 | |
#1131 | |
Thanks for the info on the cutouts. I like that option and look.
#1132 |
![]() Join Date: Feb 2019
I made a Custom Cab Cover to protect my new roof paint and Interior.
No leaves or water can get into the cowl vent or cab. Interested? PM Me for details.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA Last edited by Astro-Balls; 04-05-2020 at 11:40 PM. |
#1133 |
Nice job, but you’re 53 years too late. Kidding, if only these were used back then!
#1134 |
![]() Join Date: Jul 2015
#1135 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#1136 |
![]() Join Date: Jan 2007
seriously good idea.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#1137 |
The material I used is called
Aqualon Edge Soft, it is a tough, waterproof fabric with a soft interior lining so it is soft on the paint. https://www.youtube.com/watch?v=H2YZk-Bh3kY
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
#1138 | |
#1139 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Took first drive of 2020.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#1140 |
Transmission was getting a little tired, it was also shorter than expected! Driveshaft got dropped off for shortening today
#1141 |
![]() Join Date: Nov 2008
I finally finished up my vintage air heater/defrost install just before summer haha. Had to relocate some gauges where the heater controls now reside.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
#1142 |
This has been my virus project. Working out the wiring on my truck. I got tired of poking everything with my volt meter so I wired up some old trailer lights I had on the shop. I now have back up lights, stop lights, turn signals, and even got the dome light working. Still have not gotten the hazards to work yet but that is low on my list now.
#1143 | |
#1144 |
Installed new tarp, finished the duel exhaust. Now relaxing.
#1145 | |
#1146 |
No photos sorry. It was somewhat an ordeal.
The boost gauge was relatively simple, just removed the plate on the back of the cluster and cut it in half. Cut a clearance hole in the clear plastic faceplate and mounted the gauge using the auto meter bracket and thumb screws. The egt was more involved going in place of the factory tach. I cut a 2” hole in the clear gauge faceplate and hand filed it to fit snugly. This is how the gauge is held in place. Cut another tight fitting hole in the stamped steel panel that has the factory gauges. Then used a sheet metal uni-bit to drill clearance holes in the back of the cluster to clear the light terminal and egt probe terminals. Lastly used a razor blade to cut through the plastic membrane that connects the electrical power to the lights and gauges. Also cut the studs off the auto meter gauge. It wasn’t too bad but there were a handful of roadblocks that i didn’t foresee but was able to work through them.
#1147 | |
Membrane and ran wires to reconnect them. That was too much work for me lol. I think I'll try it your way. Thanks |
#1148 |
Installed Extang Tonneau cover, Highly recommended.
#1149 |
Finish rebuilding drivers vent window and hood hinges. Machining new rivets for the hinges took most of the day. Penning them over was not going well until I thought of my air chisel...then bingo. Hinges are now supper tight.
#1150 |
At the body shop.
Does looking at your 68 while under the 73 count.
New exhaust hangers welded on by my Son.
" That didnt make it any newer " " Dont antique the equipment " |
