Old 03-30-2020, 11:58 AM   #51
pdxhall
pdxhall's Avatar
Re: Father/Son/Friend 63 C10 Build
Great work. what size rims and tires are those? I've been looking at a similar style
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 03-30-2020, 04:55 PM   #52
cla5675
Thanks. They are American Racing VN215 Torq Thrust wheels. 20x10 rear with 275/40/20 tires and 20x8 front by 245/40/20 fronts. Hope that helps!!
cla5675 is offline   Reply With Quote
Old 03-30-2020, 07:35 PM   #53
88Stanger
88Stanger's Avatar
I have enjoyed watching your build. I am doing mine at the same time, i am a bit behind you in progress, but what else do we have to do in this virus time. Great build so far!
88Stanger is offline   Reply With Quote
Old 03-30-2020, 09:25 PM   #54
cla5675
Exactly!! Quarantine=mandatory garage time!!
Old 03-31-2020, 09:55 AM   #55
made2drag
made2drag's Avatar
sweet build! So glad you changed the wheels....those are my favorites!
made2drag is offline   Reply With Quote
Old 08-07-2020, 11:30 AM   #56
Sevens
Sevens's Avatar
Nice truck and great work!
I really like those wheels too...I just found a set on Craigslist. Trying to decide if I want to pick them up them or not. So many decisions.
-Tim
'65 GMC that identifies as a Chevrolet
Sevens is offline   Reply With Quote
Old 08-07-2020, 05:58 PM   #57
bigmoe
bigmoe's Avatar
Are those new wheels going to fit within the fenders? It looks like the Camaro wheels had a lot more backspacing and they were very close.
bigmoe is offline   Reply With Quote
Old 08-07-2020, 11:28 PM   #58
cla5675
Thanks!
Old 08-07-2020, 11:30 PM   #59
cla5675
Hey, Moe. The new wheels actually sit more inboard of the Camaro wheels. The adapters I had for the Camaro wheels were too thick.
Old 08-08-2020, 12:12 AM   #60
cla5675
Nothing too exciting but I did get some work done on the driver side cab corner, floor and rocker.
Old 08-08-2020, 12:16 AM   #61
cla5675
Few more pics:
Old 08-27-2020, 09:46 PM   #62
cla5675
Quick update. Both cab corners are done as is the driver side rocker repair.
Old 08-27-2020, 09:48 PM   #63
cla5675
...rocker repair pics:
Old 08-27-2020, 10:03 PM   #64
Captainfab
60-66 Nut
Looks Good
Old 12-04-2020, 11:15 PM   #65
cla5675
Disaster and recovery......somewhat.
Well, we had a pretty big set back on the cab. Long story short, I was working on a Lincoln Navigator for my Dad when it rolled into the cab of the truck and destroyed the back panel and pushed the firewall into a large hydraulic press. Only damage to the Lincoln was driver headlight needed replaced.
Luckily, we found another 63 cab on Facebook and picked it up the next day. We were able to use the rear cab panel as well as part of the inner window panel. Finally got it all welded and mostly metal finished. We were able to pull out and re-shape the firewall to a decent condition. Still needs a bit more metal work before primer and body work. All in all, this wasn't as bad as it could've been but I about puked when I saw the damage to the cab.
Old 12-04-2020, 11:17 PM   #66
cla5675
Donor cab:
Old 12-04-2020, 11:19 PM   #67
cla5675
Panel replacement:
Old 12-05-2020, 12:06 PM   #68
88Stanger
88Stanger's Avatar
oh damn, so sorry.
If it helps, the repair looks great, just like the rest of the build. I always say "Life happens and God has his will, so his will be done as he always has a reason for everything". So, I just pick myself up from whatever happens and move forward! You guys are doing great!
Old 12-05-2020, 12:44 PM   #69
The Rocknrod
Moderator
The Rocknrod's Avatar
Yep that's a great recovery on that cab.
Old 12-05-2020, 02:33 PM   #70
62 Barnfind
62 Barnfind's Avatar
Nice job! I remember when mine was at that stage. Keep going and one day you will be done! You also have the best color they made! Hopefully you will keep it that color.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is online now   Reply With Quote
Old 12-05-2020, 03:48 PM   #71
cla5675
oh damn, so sorry.
Thanks for the encouragement, fellas. We are keeping the original color.
Troy.
Old 01-13-2021, 09:18 PM   #72
cla5675
Monthly update time. Got the cab up on it's backside to finish some welding and noticed some filler on the p/s rocker. After a little investigating we decided to cut out the outer rocker. Found almost 1/2" of filler after cutting the original out so glad we decided to replace the rocker. A quick patch to the inner rocker and stripping it down for primer then the outer rocker is ready to for welding.
Old 06-17-2021, 11:57 PM   #73
cla5675
Short update.
Got the underside of the cab stripped, primed and laid down some Raptor bedliner. First time using the Raptor and it was pretty simple but a bit messy.
Troy.
Old 03-13-2024, 10:10 PM   #74
cla5675
Back from the dead.
Well, the 5.3 LS I built for the truck ended up in my friend's 64 Galaxie so we ordered a long block from Summit Racing. Got it all dressed up and added Ace's EFI Jackpot system. Dropped the motor and trans back in and now doing final mock up before taking the cab off one last time for some body work.
Old 03-24-2024, 03:42 PM   #75
cla5675
Got most of the front panels bolted on and doing final mock-up of the cab before removing it for paint/body. Hope to test fit the bed this coming week as well.
