Old 03-31-2020, 02:14 PM   #1
BlouDon
BlouDon's Avatar
Brake warning switch
There is a Brake Warning Switch on the brake balancer block of my truck with a Tan wire attached to it. This goes to a warning light on the dash.
What is this light meant to say?
Best regards, Philip
Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp )
Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e
Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12
BlouDon is offline   Reply With Quote
Old 03-31-2020, 02:50 PM   #2
HO455
HO455's Avatar
Re: Brake warning switch
The light will come on when one of the brake circuits isn't making as much pressure as the other one. So normally when you step on the brakes the front and rear brakes both make approximately the same pressure. Inside of the Proportioning Valve is a spool (Pressure Differential Valve in picture) that will shift away from the side with pressure to the low pressure side if the pressures are not equal.
So if the rear axle hose breaks then then pressure won't build in that circuit. Then the spool inside of the Proportioning Valve shifts and grounds the tan wire and the light lights. Warning you that something is wrong with the brakes.
Note this is not a drawing of a Proportioning Valve normally found on our trucks.
RIP Bob Parks.
Old 03-31-2020, 03:24 PM   #3
BlouDon
BlouDon's Avatar
The light will come on when one of the brake circuits isn't making as much pressure as the other one. .
Thank you!!
Old 03-31-2020, 04:00 PM   #4
HO455
HO455's Avatar
You are welcome!
RIP Bob Parks.
Old 03-31-2020, 04:54 PM   #5
FirstOwner69
FirstOwner69's Avatar
To add to HO455's great description, here's what the '69 owners manual says.
Jim
FirstOwner69 is offline   Reply With Quote
