Old 04-01-2020, 05:54 AM   #26
S10Fan
Old Heap Driver
Re: steel wheel help
I've painted 3 sets of powder coated wheels from Wheel Vintiques. Used a red 3M pad, single stage, and a cheap spray gun, they came out slick and shinny.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-01-2020, 07:13 AM   #27
That powder coat on the Wheel Vintiques steel wheels must be just a primer. It has no gloss to it and it scratches through with ease. If they didn't say it was powder coat I would not believe it was. Coarse sandpaper cuts straight through to metal with ease, like a single stroke. It sands off better than most spray bomb paint.
If you want USA wheels you can get original GM wheels widened. The guy who bought my Highlander K/20 sent out a set of GM wheels (hub centric) and had them made into 17 x 9s. It ain't cheap, but it also ain't Chinese
Old 04-01-2020, 08:32 AM   #28
3x2GTO
I'm going to check with Stockton Wheel and see about widening my stock ones. Shipping is going to be high though.
3x2GTO is offline   Reply With Quote
Old 04-01-2020, 09:17 AM   #29
SCOTI
SCOTI's Avatar
When I had wheels done by Stockton it was twice as much as just purchasing a new set through Wheel Vintiques (via Summit Racing). It was also 5x as frustrating….
Your dime. Your time.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-01-2020, 04:43 PM   #30
EricU
That powder coat on the Wheel Vintiques steel wheels must be just a primer. It has no gloss to it and it scratches through with ease. If they didn't say it was powder coat I would not believe it was. Coarse sandpaper cuts straight through to metal with ease, like a single stroke. It sands off better than most spray bomb paint...
Powder coating (applied correctly) should not sand off that easy. That sounds more like an "e coat" but I have never heard of wheels having an e-coat applied.
Sent by the random thoughts from the voices in my head...
EricU is offline   Reply With Quote
Old 04-01-2020, 04:48 PM   #31
SCOTI
SCOTI's Avatar
The ones in my possession don't seem like they're powder coated but they definitely have some type of sealer/primer coating.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-03-2020, 12:21 AM   #32
3x2GTO
WV advertises their series 82 8 lug OEM style wheels as being proudly made in the USA, not china.
Old 04-03-2020, 12:17 PM   #33
ShortHaul
ShortHaul's Avatar
I read that as well, but then I've also heard that sometimes their wait times are a few weeks to months out because they are "awaiting a shipment". Maybe its a "Assembled in USA" from overseas steel...
Either way its an American company, with solid customer service in my experience, that provides great vintage steelies for our rides... I myself have bought 3 sets from them and never once had a problem.
Free shipping from Jegs right now and a few bucks in spray paint and you're on your way. No sure if you have a Les Schwab tire shop where you're at but they did my last set, sand blasted and powdercoated white for $40 a wheel.
Untitled by awesome_adawson, on Flickr
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 04-03-2020, 04:02 PM   #34
Killer Bee
Killer Bee's Avatar
last time I called wheel vintique's for a quote, the delays were due to component manufacturing lead times.. they don't build every series all the time, they run in batches.. I suspect if they were made overseas they would be piled deep and wide..
Old 04-03-2020, 04:31 PM   #35
EricU
Wheel Vintiques prices really jump up after the 15" sizes.
Their 18" rims look to cost more that Detroit Steel's, but I haven't priced out either one with all the trim rings, center caps, clip installs.
Detroit Steel's smalled diameter is 18" and I want 17s. Not 8-lug as I have a '63 Suburban and am probably going to change over to 5-lug 5x5s.
US Wheel's look to be less expensive but I think (from my very limited research) that they are made in China or "offshore" somewhere.
Growing up in the Bay Area, I used to use Stockton Wheel years (and years and more years) ago. But after a few attempts just to get some simple answers out of them such as "Do you have 17s and if so how much?" I just gave up on them.
Old 09-28-2021, 11:06 AM   #36
77Blue
Hey ShortHaul, what back space wheel are these? Thanks in advance!
Sven
77Blue is offline   Reply With Quote
Old 09-28-2021, 12:44 PM   #37
ShortHaul
ShortHaul's Avatar
Sven
4.00 backspace on 8" wide wheel.
Old 09-28-2021, 12:49 PM   #38
SCOTI
SCOTI's Avatar
I checked w/Wheel Vintiques on the lead time for some 17" wheels. They told me mid to late December (that was 2wks ago).
If someone wants specific vs. standard back-spacing, it could be a decent wait time.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
