04-01-2020, 09:38 AM | #1 |
Replacing the “Fuel Sock”?
Here’s a thought that just came to mind.
How does one go about replacing the “Fuel Sock” in a stock in cab gas tank? And another question is, where would I get one? Do you just go in through the top front of the tank, where the fuel line comes out? I just saw a FB post, and the guy shows on picture of the remnants of his, with the caption “well it lasted 49 years”. In my 70, I’ve never replaced mine. And to my knowledge it’s still the original. If it’s a good idea to replace it, I’m gonna, so I don’t get stranded somewhere someday. |
04-01-2020, 09:53 AM | #2 |
Re: Replacing the “Fuel Sock”?
Here's one, a google search brings back others. I got one when I had to replace my sending unit.
Rg https://www.americanclassic.com/1967...CABEgI0_fD_BwE
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
04-01-2020, 10:01 AM | #3 | ||
"I ain't nobody, dork."
I got mine from here: https://www.fillingstation.com/
You just need to remove the sending unit/fuel pick up, and its right there on the end of the pick up. Easy to install, just a pain in the butt to get to. Gary
04-01-2020, 10:05 AM | #4 |
Rock auto calls it a Fuel Pump Strainer
https://www.rockauto.com/en/catalog/...+strainer,6212
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
04-01-2020, 11:29 AM | #5 |
Proprietor of Dale's Corner
I replaced the sender with a new one. The sender came with the sock.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-01-2020, 02:56 PM | #6 | |
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
04-02-2020, 06:33 AM | #7 |
70+ ( Old Skool Club )
While we are talking about gas tanks is the actual sending unit still available for our trucks. I looked on Rock Auto and didn't see one listed.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-02-2020, 09:01 AM | #8 | |
04-02-2020, 09:56 AM | #9 |
They are available, Rockauto doesn't list them though, not sure why.
04-02-2020, 12:48 PM | #10 | |
Restoration Virgin!
Be glad to sell to you $10 + shipping. I will put in truck parts forum with pictures and give you 1st dibs.
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-02-2020, 02:54 PM | #11 |
I literally just replaced my fuel sock last week. Mine had the original one which basically disintegrated. I had the clean the remnants from inside the tank.
04-06-2020, 12:20 PM | #12 |
I replaced the sock in 2013 as part of my frame off, no sure where I got it. About four months ago I had the carb rebuilt and the rebuilder told me there was a little debris in the bowls, check your filter. I opened it up, Russell 40 microns, and it was full of fine particles, I cleaned it out and replaced it. I pulled the sending unit to check the tank, the sock was mostly gone, I removed what was left and replaced the sending unit. I opened the filter again last week and its about 1/4 full again. Here's a picture with a coin to judge the particle size.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-06-2020, 03:51 PM | #13 | |
04-07-2020, 09:23 AM | #14 |
That is the debris from inside the fuel filter. I suspect it's the remnants of the sock. Not magnetic.
04-07-2020, 10:33 AM | #15 | |
04-07-2020, 03:31 PM | #16 |
Had the same problem with mine a few rears back. The sock had completely disintegrated . After the P.I.T.A. of cleaning out the tank, I installed a in line fuel filter under the cab where the fuel line comes out of the tank, and did not replace the pickup sock. Can't remember exactly, but I think I got this tip from someone on here.
