Old 03-23-2020, 01:06 PM   #1
demian5
demian5's Avatar
Replacement swing out towing mirror heads or glass and seal
When I was younger you could buy replacement mirror glass a seals for the mirrors on our suburban. Does anyone know where to source a set of replacements? Glass/seals or mirror heads?
Thanks in advance.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-24-2020, 07:16 PM   #2
ray_mcavoy
Re: Replacement swing out towing mirror heads or glass and seal
The silvering was getting bad on the mirrors on Dad's 77. We had a local glass shop cut some replacement mirror glass and I installed them into the mirror heads. I was able to carefully remove and re-use the existing seals (they were still in good shape) so I'm not sure what's currently available (if anything) for replacement seals.
ray_mcavoy is offline   Reply With Quote
Old 03-29-2020, 01:51 PM   #3
Pontiac1976
Pontiac1976's Avatar
I would try GM dealer, old glass shop. If not then your going to have to look replacement mirror that may have good looking seals but bad chrome or glass, or good mirrors. Oh I do think the seals are the same swing out towing mirror style on you truck Ford, GM, Aftermarket, 70% on the Dodge.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-29-2020, 08:23 PM   #4
Eman
They are available from Autozone. Part # Burco 2204. Maybe less from a glass shop.
Eman is offline   Reply With Quote
Old 03-31-2020, 05:03 PM   #5
demian5
demian5's Avatar
These look like they will work. Cant find any gaskets... doh, they are on the same site...
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-01-2020, 11:20 AM   #6
nekkidhillbilly
glass shops usually can get all that
nekkidhillbilly is offline   Reply With Quote
