02-05-2020, 01:39 PM | #51 |
Re: Anyone can buy an SWB...
Nice work here. I envisioned a similar bracket/attachment points for the notched x-members I've done. On mine, I just cheeped out & notched the a-arm simply because I felt the bracket required for the support bearing took away from the 'clean' look I was wanting. Unfortunately, notching eliminates aftermarket upper arms from the options because of the bushing barrel size.
02-05-2020, 01:52 PM | #52 | |
Thank you. That fitting is a return. Im dead headed now but wanted to be prepared. |
02-05-2020, 02:01 PM | #53 | |
02-05-2020, 02:27 PM | #54 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=381425
03-16-2020, 10:40 AM | #55 |
It seems like some posts were lost or something here??
Regardless, thought I would check-in & see if there were any updates.
03-16-2020, 12:55 PM | #56 |
Not sure.
Im at that stage where Im ready to get all the exterior massaged and refinished. Very stressful, and now my equities are tanking and people are buyin up all the damn toilet paper n water. Ive been talking with Empire Garage about the work. They’re a little high on their shop rate but have been turning out consistently nice work. I dont think I’ll do anything till things calm down with this pandemic mess. Depressing 😒 |
03-16-2020, 04:30 PM | #57 | |
03-16-2020, 05:10 PM | #58 |
It was a clean driver in my opinion. I was only planning to have the bed cleaned up and shot to match but I cant get the gaps where I want them w/o some precise sheet metal slice n dice. The truck had been an older refurb and the doors n fenders weren't properly hung and adjusted when they massaged it. Doors are oe, fenders are not. Now that I rehung all of it correctly things are off beyond what adjustment can fix. Sure its about as good or better than any random 2nd gen truck you would see on the road or show, for that matter, but I am obsessive about the lines. I will prolly get it aligned n drive it some before.
03-16-2020, 06:36 PM | #59 | |
03-16-2020, 10:24 PM | #60 |
Interior is done. Simple black, plastic floor, no radio, all business. I enjoy rowing through the gears n listening to the rpm’s, exhaust and gear box sounds. Not tryin tu fiddle with my phone or any of that mess. Just pure hot rod operator experience. Paying attention to all the sounds n feels of a classic rod is quite satisfying.
[ATTACH]1991843[/ATTACH [ATTACH]1991844[/ATTACH [ATTACH]1991845[/ATTACH [ATTACH]1991846[/ATTACH |
03-17-2020, 01:36 AM | #61 | |
03-17-2020, 08:22 AM | #62 |
Regardless of simplicity, that interior looks like home to me. I like it a lot.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
03-17-2020, 11:36 AM | #63 |
Cool.
I do see, though, how most people seem addicted to being distracted when they drive. Radio,phone,eating,drinking. Generally not paying attention to the actual driving and other vehicles. Its no wonder society is moving toward self-driving cars,,nobody wants to be bothered with paying attention in the moment to the experience that is driving. End sermon. |
03-17-2020, 11:55 AM | #64 | |
But, I'm not going to worry about it after I'm gone so I need to get my butt in gear first Any upgrade to the BB? What are the trans stats?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-17-2020 at 12:08 PM. |
03-20-2020, 01:20 PM | #65 |
Missed this earlier...
Block is the original 402 ( truck was a BB/TH400 model ) has a Thumper roller cam n lifters. Iron heads, bored n torque plate honed to a 409. Checked & rebalanced crank, replaced everything else. Its not a powerhouse by modern standards but Im not the boy racer type so 418/438 @ 5900 is good for now. It sounds amazing too. Trans is a 5 speed TKO model. ( 2.87 first, 1.89 second, 1.28 third, 1.0 forth, .64 fifth. Even with 373 rear gears the .64 fifth gear is pretty tall. Its great for going from town to town but I dont use it much. I also switched to a 4.11 rear so might be a better fit. Last edited by Inverter; 03-20-2020 at 02:01 PM. |
03-20-2020, 03:42 PM | #66 | |
Seriously digging this build. It has nice aftermarket parts but there's more than enough ingenuity w/the stock stuff that one might miss. it's understated!
03-20-2020, 03:55 PM | #67 |
Ahhhh...... aluminum heads .. one day...
03-20-2020, 04:10 PM | #68 |
I understand. Mine was put together a long time ago & the plan from the start was it would eventually get some lighter castings in an effort to have a lighter, powerful, mild vs. peaky final combo. I'll just say I've had more than a few years to save (LS motors didn't exist @ the time ).
My laundry list for weight saving up front was a bunch of aluminum (heads, water pump, intake, radiator, front a-arms, coil-overs, core support). Heck, it would have an aluminum block if I could get one cheap enough LoL. It also has some fiberglass inner wells waiting, & a glass/CF hood is on the list.
04-07-2020, 02:32 PM | #69 |
I'm just glad to be here!
Troy,
Just went through this whole build. I had founded along on your other OBS build in the past. I'll be doing a similar build this year to a '75 LWB, that I will be converting to SWB with an extra frame I have. I'm digging the look of the interior with the rubber mat and the exposed/painted high hump tunnel. Hope to see it some day in person. Nice work!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
04-07-2020, 03:19 PM | #70 |
Thanks Karl,
I remember you. Your a Gentleman. Maybe after this virus has run out, me n you n Scoti can meet up. I dont know how the nationals or the park are gonna go this year.. good to hear from you. |
04-07-2020, 05:06 PM | #71 |
Just here to tinker
Just went through this build. I am very jealous of your fabrication skills. Excellent work! Super thorough and beautiful truck.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
04-08-2020, 11:44 AM | #72 |
Wow, amazing work! Looks awesome!
72 Cheyenne Super swb |
04-08-2020, 12:44 PM | #73 |
Thank you
Thanks for the compliments. The thing that helped me the most was not being afraid of F’ing something up. Sometimes you end up throwing the work out and starting over. Each time I did that The 2nd version was much better. You build momentum with your confidence and skills. I forget who said : You must do the thing you think you cannot do. Words to live by. |
04-08-2020, 03:38 PM | #74 | |
Educate yourself on what you plan to work on. Research & think about what you're trying to accomplish, then do it. If you fail, figure out & understand why; then do it again making sure you overcome your previous failure. Getting your hands dirty, correcting the failures, & pushing forward definitely builds momentum which feeds your confidence ultimately improving your skills.
05-31-2020, 12:11 AM | #75 |
Don't mind me. Just doing a little dusting....
