Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Closed Thread
Old 04-12-2020, 09:34 AM   #26
tchevs
Re: 60-66 extra small stuff lots of it
Originally Posted by LostMy65 View Post
Do you know if the water temperature sensor works and is for our generation trucks?
I was looking at the pictures but can’t see a temperature sender on it. The sensors that I see are oil pressure and are for our trucks that have dummy lights instead of gauges. If I’m not mistaken there is two types of senders for our truck temperature. The one for gauges and the one for lights. The one for lights has two prongs to connect to, usually light green and dark green wires hooked to it. If you had gauges the connection is like a small button that your connection with green wire would connect to. Depending on what cluster a vehicle came with lights or gauges both sensors are common to all Chevy vehicles. Very long answer to (any junkyard V8 or straight six).
tchevs is offline
Old 04-12-2020, 05:02 PM   #27
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
It's in the red circle.
My truck had gauges.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline
Old 04-12-2020, 09:45 PM   #28
tchevs
What an eye. Yes it’s in there, not sure of its operation. I would be able to test it if I knew the ohms rating it supposed to be.
tchevs is offline
Old 04-13-2020, 12:55 PM   #29
LostMy65
LostMy65's Avatar
I found this, but I wouldn't know how to test it. Maybe put it in different temperature's of hot water and see if the ohms are at those temps.
I don't expect you to go through all that. I figured if you knew that it was correct I'd be interested.
LostMy65 is offline
Old 04-13-2020, 06:40 PM   #30
tchevs
That temp sensor is no good according to that chart. Cold or hot
tchevs is offline
Old 04-13-2020, 07:13 PM   #31
LostMy65
LostMy65's Avatar
Ok, thanks for checking.
LostMy65 is offline
Old 04-16-2020, 10:13 AM   #32
Joe P
Active Member
Hey Joe
Sick5 didn’t respond so you’re next in line. It would probably fit in a flat rate envelope, if you’re ok with it in an envelope let’s do $40 shipped to you, to cover shipping and PayPal.
Tony
Received the parts yesterday, good stuff, good packing, fast shipment! Thank you!
Joe P is offline
Old 04-18-2020, 04:51 PM   #33
Joe P
Active Member
Tony, any chance you have un-rusted cab mounts that look like the attached photos? My frame is a 1966 K20
Joe P is offline
Old 04-18-2020, 06:13 PM   #34
tchevs
These are 68 front look very similar clean yours up a bit see if you agree. Than we can measure the dimensions
tchevs is offline
Old 07-27-2020, 09:05 AM   #35
tchevs
Ttt
tchevs is offline
Old 07-30-2020, 01:20 PM   #36
Johns 66
Johns 66's Avatar
Do you have a waterpump bypass valve? Also do you have any front suspension bolts to bolt cradle to the frame
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline
Old 07-30-2020, 11:51 PM   #37
tchevs
Hello marine
I don’t have either of the parts you are looking for.
tchevs is offline
Old 07-31-2020, 12:24 AM   #38
Lokin4AReason
Lokin4AReason's Avatar
Any fotos of the jack hardware ?
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline
Old 07-31-2020, 01:15 AM   #39
tchevs
The only photo I have at the moment is post 3 part number 27. If that is the parts you are after I can dig them out and get close ups.
tchevs is offline
Old 07-31-2020, 03:28 PM   #40
Johns 66
Johns 66's Avatar
Hello marine
Thanks Brother for checking
2019 GMC AT4
Johns 66 is offline
Closed Thread
