Old 04-17-2020, 10:34 AM   #1
Mt Man Chad
Mt Man Chad's Avatar
1968 4X4 rear leaf springs ?
Looking to replace my rear leaf spring on the 68 Burb does anybody have good leads on places to purchase? I'm looking for stock height as I installed rear flip kit mounts that raises the back by 4" to match my front leaf springs already installed.
Thanks in advance!
Chad
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 04-17-2020, 05:15 PM   #2
cbeerman
Re: 1968 4X4 rear leaf springs ?
I don't know that much about springs but I was looking at these rear springs for my 68 GMC 4x4
1991-2002 C3500HD
Lenght: 56" split in the middle at 28"
Width: 3"
Arch: 4-5/8"
OEM: 15636134
MPN: 22-1009
While they look like they will physically fit, maybe someone with more knowledge could chime in
cbeerman is offline   Reply With Quote
Old 04-19-2020, 09:14 AM   #3
Mike C
Mike C's Avatar
If I remember correctly, 67-68 trucks have different size rear springs than the 69-72 trucks and are not an off the shelf solution.
Somebody like Eaton Detroit Spring could make you a set, that's where I would start. Otherwise, consider a spring swap. What is the width of your stock spring? If it is a 2 1/2" then a 56" spring from a square body truck (3/4 ton suburbans in the 80's had the longer spring. 1/2 tons usually had 52" spring) and relocating your rear hanger (again) to accommodate that length an option.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-19-2020, 10:05 AM   #4
cbeerman
The 67-68 springs are about 3.25" at the eyes and they taper to 2.5" in the middle.
The pin is in the middle and they are about 56" long
I also found that a 01 - 06 2500HD / 3500 rear spring hanger (flat style) could be made to work on 67-68. This hanger has the right spacing and allows the use of existing frame holes with room to drill the hanger
A PO on my 68 GMC SWB 4x4 added a rear bumper using a generic bracket and butchered the rear spring hangers.
I was looking to use those 1991-2002 C3500HD rear spring and the 01-06 3500 flat style hangers but found a set of 68 front and rear spring set with all the hangers on craigslist for a $100 and a 3 hr ride.
Old 04-19-2020, 01:21 PM   #5
HO455
HO455's Avatar
Try Benz Spring or Oregon Auto Spring in Portland. One of them should be able to make you a new set.
RIP Bob Parks.
