Old 04-17-2020, 01:31 PM   #1
msg
66 column shifter boot and handle questions
Is there a replacement part for this boot? And does the black knob twist off or pull off?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 04-17-2020, 01:45 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: 66 column shifter boot and handle questions
On my 63, the knob just pulls off. It's a fairly tight fit
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 04-17-2020, 02:52 PM   #3
msg
Thanks Christian, I'll give it a tug. Anyone found a replacement boot? I may have to reuse this cracked up one.
Old 04-17-2020, 03:04 PM   #4
Southcity
Southcity's Avatar
I'm amazed that you still have the boot, or part of it. It's difficult to tell from the pic if some of it has torn away over time. I *think* the part number is:
#26044259 GM Steering Column Shift Lever Seal/Boot
Searches for the above show some sites carry it but are out of stock. I have seen a similar replacement one from Dorman:
https://www.dormanproducts.com/p-75033-47102.aspx
Perhaps others will chime in with more info.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 04-17-2020, 03:18 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Truck Shop in Orange, CA has them.
Old 04-17-2020, 03:42 PM   #6
msg
Yeah the shape of the one I have assuming it's original looks so different from the others Ive seen. The dorman I think is for the floor though.
Funny you should mention them, Ive been highlighting all the money Im going to spend with them in the catalog, but I didnt see a match. I saw floor shifter boots and a grommet. Ill try giving them a call.
Old 04-17-2020, 04:09 PM   #7
Southcity
Southcity's Avatar
fyi: I gave The Truck Shop in Orange a call but they didn't have them nor the anti-rattle bushing for the tilt column shift lever.
It looks like Amazon has them:
https://www.amazon.com/Genuine-GM-26.../dp/B00GTJWWM0
Old 04-17-2020, 05:09 PM   #8
The Rocknrod
Moderator
https://67-72chevytrucks.com/vboard/...19&postcount=2
Old 04-17-2020, 06:02 PM   #9
msg
Thanks for checking with them. I didnt know I needed that anti rattle bushing..more stuff to find.
Thanks Rocknrod, that catalog looks like a match to what I have. Ill send an email to them to get a quote on shipping it to the states.
I wonder if that lever shim is the canadian version of the anti rattle bushing?
Old 04-17-2020, 08:25 PM   #10
66x3
Anybody know if you can put the old style 63-66 knob on the next generation 67-72 shift lever ? Newer style shaft looks bigger diameter but maybe not the part where the knob slips on?
66x3 is offline   Reply With Quote
Old 04-18-2020, 11:37 AM   #11
Southcity
Southcity's Avatar
I wonder if that lever shim is the Canadian version of the anti rattle bushing?
Not sure but it sure looks like that shim will help with shift lever rattle when driving rough roads. Keep us updated if you end up purchasing these parts.
Old 04-23-2020, 10:07 AM   #12
Afirehawk1
does someone make a replacement handle for a 66?
mine is all rusty but the rubber boot is perfect.
Afirehawk1 is offline   Reply With Quote
Old 04-23-2020, 10:36 AM   #13
The Rocknrod
Moderator
The Truck Shop in Orange, CA in the catalog I have it's page 66.
Old 04-23-2020, 10:53 AM   #14
Afirehawk1
thanks!
