Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Closed Thread
Old 04-18-2020, 02:36 PM   #151
bamabronc
Re: 67-72 Chevy Truck fuel gauge diagnostics 101
Originally Posted by bamabronc View Post
More info. With the gauge outside of the cluster and hooked up, it works. I’m thinking it must be something with how I have the resistor on or the wiring coming into the cluster. Does anyone know what the readings should be on each wire at the plug?
Also, feed wire at plug is 90 ohm, but once plugged in it goes to 36 ohms.
bamabronc is offline
Old 04-18-2020, 02:40 PM   #152
bamabronc
Originally Posted by 67 Burb View Post
OK. I missed your last post as I was posting mine. Now you know that the sender is OK and the gauge works out of the dash unit, make sure the gauge cluster is well grounded.
Where did you test the sender from? At the sender or from under the dash?
I have tested the sender both in the tank and out. Ohms moved as it should while moving the float up and down. The tank is full and reading 90 ohms. At the dash plug and tank both read 90 before plugging up to the cluster
It’s weird. Seems to work until I connect the printed circuit
Old 04-18-2020, 03:38 PM   #153
67 Burb
67 Burb's Avatar
Yes, once you plug it in, you are introducing more circuitry into the ohm measurement.
Run a wire from the ground stud on the back of the gauge to a good ground.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline
Old 04-18-2020, 03:45 PM   #154
67 Burb
67 Burb's Avatar
The one I have the black jumper on.
Bob
67 Burb is offline
Old 04-18-2020, 03:51 PM   #155
bamabronc
Tried grounding stud with a wire and no change while harness plugged in
Old 04-18-2020, 04:02 PM   #156
67 Burb
67 Burb's Avatar
I'm stumped. All seems to be OK, but still it doesn't work.
Bob
67 Burb is offline
Old 04-19-2020, 07:11 PM   #157
bamabronc
Here is a great YouTube explanation on fuel gauges I thought I would share. It covers the resistors and such. https://youtu.be/bVT2Jh_p02A
Old 07-03-2020, 08:17 PM   #158
57taskforce
All about them K’s
57taskforce's Avatar
I just wanted to thank Vettevet and Tbone for this great thread. I had to replace my gauge resistor but thanks to this thread I was able to get my gauge working again. You guys are awesome.
Tyler
57taskforce is offline
Old 07-03-2020, 11:04 PM   #159
TBONE1964
Cluster King
TBONE1964's Avatar
Glad the information provided has helped you. It's always a pleasure to help .
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline
Closed Thread
