Old 04-21-2020, 09:36 PM   #1
salty388
Leaf Spring Drop
I have a 70 GMC with leaf spring rear and the PO did a flip kit and ended up dropping it 8" to where the frame sits on the axle. He put 3" drop springs in the front. I love the way the front sits but plan to do spindles and disc brakes in the future. What is my best option for a 5" from stock drop on the rear? Unflip the axle and do 5" drop springs? Keep the flip and somehow raise it 3"? Also is a c-notch required with either option? Maybe there's a better way to go about it too. I'm new to the leaf spring rear setup and there doesn't seem to be a lot of info out there on them.
salty388 is offline   Reply With Quote
Old 04-22-2020, 08:13 AM   #2
Mike C
Mike C's Avatar
Re: 2.25" Leaf Spring Drop
Your only real option is go back spring under with drop leaves to get anything more than 1.5" drop using shackle or 7"+ drop of the flip. The flip on my short step resulted in a 7" drop and I run it without a notch.
I would buy a 5" rear drop spring and a set of lowering shackles to fine tune the final ride height.
That 3" drop spring might be just a touch too much combined with spindles. I run a 2" spring with the spindles on mine.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-22-2020, 10:28 AM   #3
MDPotter
MDPotter's Avatar
Do you mean spring over?
I installed 4" drop springs from Western Chassis on mine and got a little over 3" of drop out of them. I'm assuming this is because the stock springs had sagged over time.
If you want to get to to 5", I would start with 4" or 5" drop springs and then do shackles if the springs don't get you low enough. Be aware that shackles might require notching of a bed cross sill for clearance.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 04-23-2020, 12:03 AM   #4
salty388
Ok I plan to order either Western Chassis 4" or CPP 5" leafs(whichever I can get in a timely fashion) and drop shackles. Anybody know where I can get factory hardware for the "unflip"?
As far as the front I was planning to go to a 1" drop spring and 2" modular spindles from CPP for a 3/5 drop.
Thanks for the help so far! I just bought this truck and am still learning a lot about it.
Old 04-23-2020, 08:12 AM   #5
Mike C
Mike C's Avatar
Yes, I meant spring over.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-23-2020, 09:24 AM   #6
MDPotter
MDPotter's Avatar
You can buy new u-bolts from POL: https://www.performanceonline.com/Ub...-72-Chevy-C10/
And if you cut the perches off your axle: https://www.performanceonline.com/19...ar-Axle-Seats/
I don't know where to get the plates that the u-bolts run through. Maybe a junkyard or look in the classifieds here.
Old 04-23-2020, 04:37 PM   #7
dz1087
So, my bolt plates were rotten when I got my truck. Instead of paying a bunch for new plates, I got spring plates for a YJ wrangler, and U-bolts from O'Reilly's that fit. This flips the spring plate to the top, so it is less likely to catch water and rust out again, and you use rounded U-bolts instead of the regular square ones.
Works fine. Half the price for new parts.
dz1087 is offline   Reply With Quote
