04-26-2020, 11:26 PM | #1 |
60lb oil pressure gauge and LS Swap
Im doing a ls swap on my truck and I am concerned about the factory 60lb oil pressure gauge. How well does it hold up or do I need to just change it to the 80lb gauge? Thanks in advance, Carl
04-26-2020, 11:33 PM | #2 |
Re: 60lb oil pressure gauge and LS Swap
Its not going to leak or break its a very sturdy gauge. I had a 60 on my cummins for a lomg time, unless hot in the summer it was always pegged. No issues
04-26-2020, 11:33 PM | #3 |
I did see a clean 80 psi guage on the parts forum today....
04-26-2020, 11:34 PM | #4 |
Ok, thanks. I knew it would peg out but wasnt sure how it would hold up.
04-26-2020, 11:43 PM | #5 |
04-27-2020, 12:57 AM | #6 |
04-27-2020, 02:13 AM | #7 |
04-27-2020, 08:08 AM | #8 |
Why would you think an LS would have more psi than any other motor?? I have a stock gage with normal psi
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
04-27-2020, 09:22 AM | #9 |
I know they idle at about 40lbs when hot, and around 50 or maybe a little more cold. but when you are wide open throttle i have seen 70 to 80lbs and with a 60lb gauge i didnt know if it would hold up.
04-27-2020, 10:17 AM | #10 |
Isn’t the oil relief valve set 60 PSI
04-27-2020, 12:52 PM | #11 |
I also have a high volume pump. Not sure about the relief valve.
