Old 04-29-2020, 02:46 AM   #1176
MACO
MACO's Avatar
Re: What did you do to your truck today.The 3rd chapter
Finally had the time to weld up and grind smooth groves worn on the rear brake backing plates where the brake shoes ride. After over 50 years of use the grooves were substantial and the shoes would bind in them. Also replaced the shoes and spring kit, rear brakes are operating so much smother and quieter.
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green.
MACO is offline   Reply With Quote
Old 04-29-2020, 04:03 AM   #1177
Metaldoc
Metaldoc's Avatar
Out of winter storage
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 05-01-2020, 03:00 PM   #1178
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
The lower door moldings on my C20 were barely hanging on, and I really wanted to see the front hole. Anyway, I just reinstalled them and I'm pretty happy with it.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-01-2020, 03:17 PM   #1179
toolboxchev
Just going through my brakes again myself. Question if I may where are you sourcing parts from?
toolboxchev is offline   Reply With Quote
Old 05-01-2020, 04:27 PM   #1180
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
This was a couple of week project. Test fit and didn't like the way it looked or fit. I made brackets to sit it the way I wanted. I'm happy with the end result.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-01-2020, 04:34 PM   #1181
71CHEVYSHORTBED402
Nothing quite like a sleeper.
Tony
Old 05-01-2020, 08:55 PM   #1182
Metaldoc
Metaldoc's Avatar
She's fully loaded, no cruise control that's it. Thanks
Old 05-02-2020, 08:23 AM   #1183
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
I got another tach dash done. Waiting on parts for the other one.
Both will have tach's, and LED bulbs installed. I reset the odometer back to 00000 also!
I called Manes truck parts to check on a order and got to talking to the owner, he is sending me some NOS tach housings and inserts he had plus he called me back later and said he put some needle paint in the shipment also for free!
I'm going to have the speed warning back together soon also I hope. I had TBone1964 refurb it for me.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-02-2020, 09:19 AM   #1184
BugzC10
BugzC10's Avatar
Nice work Andy!Building a relationship with your suppliers is always a good thing.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 05-04-2020, 12:04 PM   #1185
Davidf
Finally repainted the interior, cowl area, and jambs of my Ochre 71 C10. PO had repainted the truck a generic yellow (hood in photo that has not been repainted yet) that was in dire need of help. Back to original Ochre but a long way to go.
Davidf is offline   Reply With Quote
Old 05-04-2020, 12:14 PM   #1186
67C10Step
67C10Step's Avatar
Finished rebuilding my vent doors. Tear apart, blast, repaint and re-assemble with new seals. Just stuck them back in some zip loc bags and into my parts bin. Far from ready to re-install them but I had the parts and the time this weekend.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 05-06-2020, 01:08 AM   #1187
Astro-Balls
Astro-Balls's Avatar
Finished wiring up the new Washer pump and connecting the Washer Reservoir, Nice to have clean windows at the touch of a button..
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 05-07-2020, 12:09 AM   #1188
3757chevy
3757chevy's Avatar
Gotta love it.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 05-07-2020, 06:56 PM   #1189
tdangle
tdangle's Avatar
Installed a Lokar cable shift setup on my automatic. Then removed and and went back to the rod system.
The cable system did not work for me at all. Has anyone made this work?
Also installed a holley bracket and solenoid for increasing the idle with the AC running. Had to trim the bracket as it interfered with the throttle linkage and held the throttle open. Can believe Holley can't make a bracket for their carbs (new street avenger) that works without modifications
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 05-07-2020, 09:37 PM   #1190
zicc1835
zicc1835's Avatar
I'm interested to know I have the rod system and am not near ready to install it on my project truck 700r4 and was thinking of going to the cable thought it would be easier .....what didn't work?
zicc1835 is online now   Reply With Quote
Old 05-12-2020, 04:28 PM   #1191
ohboy321
ohboy321's Avatar
Finished sanding and prepping my steering wheel getting it ready for epoxy.
Steve/NH
1967 K10 327 Short Bed Stepside
2008 F350 Power Stroke Lariat
2007 BMW X3
2023 BMW X3 M-Sport
2020 BMW 540xi M-Sport
1995 Harley FLSTC
ohboy321 is offline   Reply With Quote
Old 05-12-2020, 06:42 PM   #1192
tdangle
tdangle's Avatar
I could not get it to line up anywhere close with the column gear positions. and it did not work very smooth. Went back to the Lokar rod system and works perfect just transmits vibration due to the idle quality of my cam.
Terry
Old 05-12-2020, 09:45 PM   #1193
zicc1835
zicc1835's Avatar
thanks
Old 05-13-2020, 03:24 PM   #1194
Davidf
Got the "white" on the cab
Old 05-14-2020, 10:17 AM   #1195
tdangle
tdangle's Avatar
does the white go into the door jam at the middle? Could you post a picture looking the the door jam toward the striker plate area?
Terry
Old 05-14-2020, 12:02 PM   #1196
j_cst_10
j_cst_10's Avatar
Found and installed the largest air cleaner I could fit! Had to take the alternator off to shoe horn it in.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 05-14-2020, 03:21 PM   #1197
toolboxchev
How come you did the Beer Cooler Delete? I would have kept that one intact, boy talk about finding another one of those!
Old 05-16-2020, 09:22 PM   #1198
Stover93
Originally Posted by Stover93 View Post
Paint test on an old fender. Hugger orange vs Ford lightning blue.
Tangier orange vs hugger orange this time.
Stover93 is offline   Reply With Quote
Old 05-16-2020, 09:33 PM   #1199
67C10Step
67C10Step's Avatar
I installed a new vacuum advance and cleaned up the mechanical advance. She doesn’t stumble off idle any more.
Pulled both front inner fenders in preparation to pull the whole front suspension out. It wasn’t totally necessary but figured the extra room would not hurt. Found the front fenders in pretty good shape but the core support and right inner fender rough.
Also put the Chevrolet license plate on the front that I had on my 70 model when I was 16. That was 34 years ago.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 05-16-2020, 09:35 PM   #1200
67C10Step
67C10Step's Avatar
The blue shows the body lines better.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
