Replacement Grille for 83-84 GMC
Does anyone know of a source for an 83-84 GMC single headlight replacement grille? I can find the Chevy version, but havent found the GMC.
Thanks.
Bob Q. '83 K2500 6.2L |
Re: Replacement Grille for 83-84 GMC
I would love to know the answer to this question too. I don't think there is a source other then finding a decent used one and restoring it.
Yeah mine is getting pretty weathered and I haven’t been able to find any replacements. Guess I better start looking in the junkyards.
They are hard to find... I am having trouble finding one for my '83 GMC suburban with dual headlamps.
The only thing I found close I think is at LMC or Classic Industries. 81-82 GMC grill but no letters. I need a new 84 GMC single light grill too
It should be a little bit easier to find single headlight 83-84 because lots people switched to dual head lights. So it just to find the one that have them sitting in there shop or home in the back. It's been about 2 yr the after market duals out of stock. Because I use to sell some parts for the dual grab the wiring harness for the dual head when I came across good one the where not cut up so it would be a plug play conversion to duals.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
