Old 04-30-2020, 09:21 AM   #1
Furno68C20
Brake booster/master question 3/4 to 1/2??
I have a 67 1/2 ton that has manual brakes. The master cylinder is filled with debris and no fluid since its been sitting for a number of years. This truck is Drum/drum
I have a 68 3/4 ton that i just put disc conversion on, it was previously Drum/drum with power breaks. This master and booster is in good working condition.
My question is can i put 3/4 power brake set on the 1/2? I see that the booster extends the master cyl / distribution valve brake line ports forward. What would be the best solution here..new lines? just extend the lines? any size difference in brake lines?
here are a few pictures.
1/2 ton on the left 3/4 ton right.
What is that rubber washer? does that go between the master and booster?
sorry about the side way picture.
Thanks in advance!
67 C10 Fleetside SOLD
67 C10 SWB Fleetside
67 C20 Fleetside
68 C10 Fleetside
68 C20 Fleetside SOLD
72 k20
Pay Pal: Grant.Furneaux@gmail.com
Furno68C20 is offline   Reply With Quote
Old 04-30-2020, 10:08 AM   #2
Sheepdip
Sheepdip's Avatar
Re: Brake booster/master question 3/4 to 1/2??
The rubber washer is the end seal for the booster that is held in by the master cylinder, it goes on the push rod just like you've got it in pic 3.
Install the push rod, slide the rubber washer on and seat it in the end of the booster, then bolt the master up.
The push rod will have a little adjustment screw on the end that goes into the master, there should be about a 1/32 to 1/16 gap before it makes contact with the master piston. You can check it with contact grease/putty to assure you're gap is correct.
Sheepdip is offline   Reply With Quote
Old 05-01-2020, 12:24 PM   #3
Furno68C20
Ok thank you. anyone else??
67 C20 Fleetside
68 C10 Fleetside
72 k20
Old 05-01-2020, 01:22 PM   #4
notsolo
notsolo's Avatar
This is a common upgrade, I put a bigger booster and MC...on my 72....works fine.
notsolo is offline   Reply With Quote
