Old 05-01-2020, 09:40 AM   #126
youngrodder
youngrodder's Avatar
Re: 53 3100 - complete rebuild and upgrade . . . .
Originally Posted by big_dan View Post
A little more progress on the trans xmember. Still a little rough but we'll refine it a bit later. Moving along -
Dan
Looks great. I dig those mounting tabs....very cleaver...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-01-2020, 10:47 AM   #127
dsraven
good to see a beefy cross member in there. since the frame has lost the old cross member behind the engine the frame will be prone to flex some between the front and trans cross members. this can affect the cab mounts and some fellas have had issues with the door gaps changing and doors closing properly. big HP will also make it worse. the cross member you built looks beefy though.
just another thing to consider.
nice machine work you are doing, impressive work and planning processes.
keep the pics coming, they stoke the rest of us a bit to get us off the couch.
Old 05-01-2020, 09:38 PM   #128
big_dan
Thanks for the input, fellas.
As for the frame flexing, I'm not completely finished with the support between the front and rear, but wanted to get everything mounted first (engine, trans, headers e.t.c) before I fully draw it out. That way, I'm not fighting it later. The plan is to integrate everything from the motor mounts and trans mount to the driveshaft loop, so there's plenty left to cipher on. Plus, the boxed frame should help too.
More later - thanks for looking -
Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . .
My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean.
https://www.67-72chevytrucks.com/vbo...d.php?t=791886
My 65 Ford project . .
https://www.67-72chevytrucks.com/vbo...d.php?t=792428
big_dan is offline   Reply With Quote
Old 05-12-2020, 07:32 PM   #129
big_dan
Just a little progress to keep motivated. Once the old bass boat comes out it's hard to get shop time !! Finished getting the crossmember mocked up and got the slugs tacked in, so it's something anyway.
More later -
Dan
Old 05-12-2020, 08:04 PM   #130
joedoh
joedoh's Avatar
super nice!
Old 05-13-2020, 03:28 AM   #131
NorCalGal
NorCalGal's Avatar
You do very nice work sir.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 05-13-2020, 08:58 AM   #132
youngrodder
Great detail.....it takes time. There are no short cuts with this build.
Bravo...
Marc
Old 05-14-2020, 12:15 AM   #133
mongocanfly
mongocanfly's Avatar
very slick on the trans crossmember..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-14-2020, 05:32 AM   #134
big_dan
Thanks for the compliments. Should get it welded up in the next week or so then I guess I'll start headers. That's always fun!
Thanks for looking -
Dan
Old 05-14-2020, 08:38 AM   #135
olcarguy
Nice job sir....
olcarguy is offline   Reply With Quote
Old 05-21-2020, 05:05 AM   #136
big_dan
Not a lot of progress, but the crossmember is done for now, so time to get the 5.3 and cab back on and move to the next item.
Dan
Old 05-23-2020, 07:54 PM   #137
big_dan
Headers next?
More later -
Dan
Old 05-24-2020, 06:07 PM   #138
dsraven
Would be good to have a cab on there to mock up steering column angle before getting headers, maybe.
Old 05-24-2020, 08:16 PM   #139
big_dan
Agreed, of course. Slapping the cab back on is no biggie. I'll get the cab back installed and do the passenger side first. Plan for the driver's side is to get the column and steering shaft complete, then build headers.
So really, I should have said headers-firewall-column-steering next LOL.
Thanks for looking-
Dan
Old 05-31-2020, 07:25 PM   #140
big_dan
Another minor update.
Last set of headers I built I started with "U" and "J" bends. This set, I had an epiphany and thought I'd start with a pre-bent set and see how that works out. Either way there's substantial fabwork involved, but I thought it was worth a shot. So, here goes the passenger side while I ponder steering columns and such on the driver's side. FYI 1-3/4" with 3" collectors, planning to have cutouts right behind the H-pipe.
As you can tell, no where close. Yet.
More later-
Dan
Old 06-19-2020, 04:49 AM   #141
big_dan
Slowly but steadily making progress on headers. Started on the passenger's side, should have everything tacked up soon I hope. Went ahead and grabbed my booster, steering column, u joints, heim joints and DD shaft so we can attack the drivers side when this is finished. No where near final yet, just showing a little progress.
Dan
Old 06-19-2020, 06:50 AM   #142
reaper71
reaper71's Avatar
looking good
Mark
reaper71 is offline   Reply With Quote
Old 06-19-2020, 07:43 AM   #143
youngrodder
Looks great. Keep at it..
Marc
Old 06-22-2020, 04:28 AM   #144
big_dan
Thanks, fellas.
One more piece, moving forward. Ididit steel column (not SS, going to paint it), 30", 1" DD shaft, tilt and turn signal with universal GM harness, no shifter. I'll start this once I finish the passenger side. Kicking around the idea of making my own wheel, but we'll see about that.
More later -
Dan
Old 06-22-2020, 08:23 AM   #145
youngrodder
Thanks, fellas.
More later -
Dan
Looks good Dan....I went with the same column and painted mine as well. On my previous truck (48') I had the chrome column and it was too much bling for my liking...
Marc
Old 06-23-2020, 10:55 AM   #146
big_dan
Youngrodder - I didn't think I'd like a chrome column either. Thanks for looking-
A little header progress. Passenger side is fitted up. I kicked out the rear tube for length; that keeps all 4 tubes within a few inches of each other. I may change it, so I'll not weld them up yet. Pics are pretty self- explanatory, so I'll shut up and study on the drivers side a bit. . . .
More later -
Dan
Old 06-23-2020, 11:09 AM   #147
youngrodder
Looks good Dan... That header look slick. Well done
Marc
Old 06-23-2020, 12:21 PM   #148
Desert1957
Desert1957's Avatar
Very nice job on the headers.Looks great!
Desert
Desert1957 is offline   Reply With Quote
Old 06-23-2020, 12:53 PM   #149
8man
Good job on the headers.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 06-23-2020, 02:27 PM   #150
mongocanfly
Really nice...I had a buddy that built his own headers for his wagon from scratch...lots and lots of work hrs in them..yours look great
Mongo...aka Greg
RIP Dad
RIP Jesse
