#1176 |
![]() Join Date: Sep 2005
Re: What did you do to your truck today.The 3rd chapter
Finally had the time to weld up and grind smooth groves worn on the rear brake backing plates where the brake shoes ride. After over 50 years of use the grooves were substantial and the shoes would bind in them. Also replaced the shoes and spring kit, rear brakes are operating so much smother and quieter.
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green. |
#1177 |
Out of winter storage
Do it, Do it right, Do it right the first time |
#1178 |
![]() Join Date: Feb 2009
The lower door moldings on my C20 were barely hanging on, and I really wanted to see the front hole
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-01-2020 at 04:13 PM. |
#1179 | |
![]() Join Date: Jul 2015
#1180 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
This was a couple of week project. Test fit and didn't like the way it looked or fit. I made brackets to sit it the way I wanted. I'm happy with the end result.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#1181 |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#1182 |
She's fully loaded, no cruise control that's it. Thanks
#1183 |
Old member
I got another tach dash done. Waiting on parts for the other one.
Both will have tach's, and LED bulbs installed. I reset the odometer back to 00000 also! I called Manes truck parts to check on a order and got to talking to the owner, he is sending me some NOS tach housings and inserts he had plus he called me back later and said he put some needle paint in the shipment also for free! I'm going to have the speed warning back together soon also I hope. I had TBone1964 refurb it for me. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#1184 | |
1970 C10 Short Stepper with 71/72 front clip. |
#1185 |
Finally repainted the interior, cowl area, and jambs of my Ochre 71 C10. PO had repainted the truck a generic yellow (hood in photo that has not been repainted yet) that was in dire need of help. Back to original Ochre but a long way to go.
![]() Last edited by Davidf; 05-04-2020 at 12:13 PM. |
#1186 |
Finished rebuilding my vent doors. Tear apart, blast, repaint and re-assemble with new seals. Just stuck them back in some zip loc bags and into my parts bin. Far from ready to re-install them but I had the parts and the time this weekend.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#1187 |
![]() Join Date: Feb 2019
Finished wiring up the new Washer pump and connecting the Washer Reservoir, Nice to have clean windows at the touch of a button..
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
#1188 | |
![]() ![]() Join Date: Mar 2016
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#1189 |
![]() Join Date: Mar 2005
Installed a Lokar cable shift setup on my automatic. Then removed and and went back to the rod system.
The cable system did not work for me at all. Has anyone made this work? Also installed a holley bracket and solenoid for increasing the idle with the AC running. Had to trim the bracket as it interfered with the throttle linkage and held the throttle open. Can believe Holley can't make a bracket for their carbs (new street avenger) that works without modifications
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#1190 | |
![]() Join Date: Mar 2011
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#1191 |
![]() Join Date: Aug 2015
Finished sanding and prepping my steering wheel getting it ready for epoxy.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
#1192 |
I could not get it to line up anywhere close with the column gear positions. and it did not work very smooth. Went back to the Lokar rod system and works perfect just transmits vibration due to the idle quality of my cam.
#1193 |
thanks
#1194 |
Got the "white" on the cab
#1195 |
does the white go into the door jam at the middle? Could you post a picture looking the the door jam toward the striker plate area?
#1196 |
![]() Join Date: Nov 2008
Found and installed the largest air cleaner I could fit! Had to take the alternator off to shoe horn it in.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
#1197 |
How come you did the Beer Cooler Delete? I would have kept that one intact, boy talk about finding another one of those!
#1198 |
![]() Join Date: Jun 2019
Tangier orange vs hugger orange this time.
#1199 |
I installed a new vacuum advance and cleaned up the mechanical advance. She doesn’t stumble off idle any more.
Pulled both front inner fenders in preparation to pull the whole front suspension out. It wasn’t totally necessary but figured the extra room would not hurt. Found the front fenders in pretty good shape but the core support and right inner fender rough. Also put the Chevrolet license plate on the front that I had on my 70 model when I was 16. That was 34 years ago.
#1200 |
The blue shows the body lines better.
