Old 05-04-2020, 03:24 PM   #1
TXGREMLIN
steering wheel swap
Hi guys,long time lurker here and first time posting.
I have a 78 chevy c10 and want to swap the steering to one out of a 99
suburban but i'm not sure if it will fit.
Anyone knowif it will fit on the 78?
I'm talking about the air bag wheel.
TXGREMLIN is offline   Reply With Quote
Old 05-04-2020, 04:09 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: steering wheel swap
No. not unless you make a adapter
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-04-2020, 05:10 PM   #3
What Pontiac said. Airbag style columns/wheels use a different spline than earlier ones. If it was a 94 or early wheel it would work.
Old 05-04-2020, 05:24 PM   #4
TXGREMLIN
Thanks guys,guess i'll see if they have one of the earlier ones out there.
Old 05-04-2020, 07:46 PM   #5
This is the one I put in my truck. From the 88-94 era.
Old 05-04-2020, 11:43 PM   #6
TXGREMLIN
I think I saw a couple of those out there too,I'll look next time I go out there.
Old 05-05-2020, 06:05 AM   #7
Dead Parrot
IIRC - most pre air bag GM steering wheels use the same spline/bolt/horn setup. So a Pontiac wheel will mount on a Chevy column. It may not match style wise however. Just be sure to get ALL the horn parts.
When I picked up a replacement steering wheel for my 75, I test fit 3 on a wheel-less column before picking one from a Blazer. I liked a Pontiac wheel but it had a square base that didn't match very well to the round Chevy column.
Dead Parrot is offline   Reply With Quote
