Old 05-06-2020, 01:00 PM   #1
HeavyHauler
Can somebody get some pics of factory sway bar bracket shape for 68-72 C10?
I think the prior owner of my 1968 Chevy C10 SWB had most likely bumped into something with one or both of the front factory sway bar brackets and may be bent. Could somebody post some pics of factory sway bar brackets that are good and not bent or altered.
If one or both are bent I would like to try and bend it back into original shape like factory.
HeavyHauler is offline   Reply With Quote
Old 05-06-2020, 01:22 PM   #2
bry593
Re: Can somebody get some pics of factory sway bar bracket shape for 68-72 C10?
Common problem. Should be obvious if bent. The bracket that bolts to the frame has a surface where the bushing strap holds the bushing in place. This area should be parallel with the ground. If not, it is bent.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 05-06-2020, 02:30 PM   #3
phlegm
Still Green but learning
phlegm's Avatar
Ill grab them in a minute, I re-did my bushings this year so the goo is even wiped off (LOL)
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 05-06-2020, 02:44 PM   #4
phlegm
phlegm's Avatar
Here you go. I even flipped the truck upside down for that last one so you could get a better angle no extra charge, its a feature!
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 05-15-2020, 10:24 PM   #5
HeavyHauler
Thanks for posting these pics. They really helped me today as I got the bracket straightened and looking good!
