05-07-2020, 11:08 PM | #126 |
Re: '72 Cheyenne K10
You have a factory Air Condition cab. You might want to think about vintage air if you are really going to fix it up.
05-09-2020, 09:10 PM | #127 |
I took the truck on it's longest drive a few miles across town today. Brakes could definitely be better. A friend is helping me with building a center console from scrap cedar. Stopped by my friend's new brewery to pick up a couple crowlers on my way home.
05-11-2020, 05:41 PM | #128 |
I am so frustrated with the brakes on this truck. Two shops looked at it and told me the booster isn't big enough. Booster manufacturer says it is plenty big. No shops want to work on it at all. I have bled and bled again and bled again. The brakes suck. They slow down okay, but are terrible for stopping. I have to grab the steering wheel and push with all my might to the floor to stop on a downhill driveway. If a dog, cat, or child jumps in front of me they are dead for sure.
05-11-2020, 06:05 PM | #129 |
Maybe a vacuum leak somewhere is taking away from the booster?
You can always switch to hydroboost...it's pretty sweet.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
05-14-2020, 05:30 PM | #130 |
Center console project is finished (except bolting to the seat frame). I think it turned out pretty good.
05-15-2020, 08:07 AM | #131 |
Proprietor of Dale's Corner
console looks great.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
05-15-2020, 12:07 PM | #132 |
Truck looks great!
05-16-2020, 02:47 PM | #133 |
Thanks guys!
I changed the oil today (yeah, I know I should have done that when I first got it). The filter was seriously stuck on and started to crush with a strap wrench. I turned to YouTube and found this cool trick to drill some holes and put screws through an oil filter socket into the oil filter. This worked much better than stabbing a screwdriver through it. |
05-16-2020, 03:20 PM | #134 |
Carpe manana
Stabbing the screw driver. Been there that’s a mess.
05-16-2020, 06:39 PM | #135 |
I also took the passenger side hub apart to replace the rotor today. The bearings look good, so I'm just going to repack everything with new grease.
05-16-2020, 10:05 PM | #136 |
From these pictures, it looks to me like that rotor is glazed over. Hopefully your brakes will be more responsive after you replace it.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
05-16-2020, 10:10 PM | #137 |
The rotors needed to be replaced for sure. I'm not about to ruin new pads on them.
05-16-2020, 10:31 PM | #138 |
Hey jimbosprint
Nice thread I met you briefly the other day But I really didn’t know Until now It was raining And I had a long drive in front of me Last edited by Chevyland; 05-16-2020 at 10:38 PM. |
05-17-2020, 12:56 AM | #139 |
Right on Chevyland. I'm glad that orange/white truck has a good home. I told my neighbor he shouldn't sell it.
05-17-2020, 09:00 AM | #140 |
Last summer, I had poor braking for a while until I realized that the rear shoes needed more adjustment out. Turned in the star wheel to get the drums off and didn’t get set out enough. Discovered this when wife set the parking break and I dint know about it until the first stop and was like whoa, that is a lot better what changed. If you haven’t set the shoes yet that may help as well. My thought is all the initial boost was used to close the air space. Hope this helps.
Very nice truck btw, I too love the color.
1972 C30 2WD 157” WB |
05-17-2020, 06:40 PM | #141 |
You never know what you will find when you take em apart. Driver side hub was very rusty. WD40 is good stuff. I think most of the parts can be saved, but I am tempted to replace the bearings at least. Any advice from the peanut gallery?
05-17-2020, 06:45 PM | #142 |
Carpe manana
Soak the rusty hub dial pieces in Evaporust if not pitted and gone. Once the rust is gone lube and install. http://67-72chevytrucks.com/vboard/s...0&postcount=18
05-18-2020, 07:11 AM | #143 |
Personally, I would replace bearings/races.
05-18-2020, 06:02 PM | #144 |
I got the driver side back together. I had a little trouble with getting the bearing adjusted, but I think I have it right. The locking hub works good now.
The new pads rub a little on the new rotors. I am sure the caliper was opened all the way up. I hope the problem solves itself with a little use. |
05-20-2020, 10:53 AM | #145 |
Passenger side hub is back on, but I didn't get the caliper back together yet. This hub lock is more difficult to get into the free setting for some reason. Everything feels like it moves smoothly inside to me.
05-20-2020, 07:18 PM | #146 |
I got the passenger side back together today and went for a test drive. The brakes slow down in a hurry just fine, but they are not good at stopping. There is no locking up the wheels. It isn't possible. Plenty of brake pedal there, but they are squishy and it takes a lot of leg to stop. Maybe the booster is bad. I don't know what to do.
05-22-2020, 03:01 PM | #147 |
I’m not an expert, but I recommend bleeding the system again. I say that because you say the pedal is squishy. I’ve gone through your thread but I don’t remember if you got a new master cylinder, if you did get a new master cylinder did you bench bleed it first?
05-23-2020, 12:23 AM | #148 |
Yes, I did bench bleed the new master cylinder. I am probably going to take it all apart and bench bleed it again. Someone suggested I pinch the brake hoses off with vice-grips to see how the pedal feels. It was also suggested to disconnect the vacuum to see if it feels different. I don't know what else to do.
06-02-2020, 12:59 PM | #149 |
I just ordered chrome bumpers. I can't find anyone to take thousands of my dollars and fabricate some nice tube bumpers for me, so instead it goes to reproduction parts. I am done wasting my time on people that lie when they say they can work on it in two weeks.
06-02-2020, 09:03 PM | #150 |
Carpe manana
What are your thoughts on adding a push bar/brush guard?
Tags |
ochre |
