trans cross member information
I am changing from 3ott to automatic trans and the cross member for the 3ott is in the way. It is riveted in top and bottom in 4 places. I can't get to the 2 top rivets because they are under the cab, so what is the best way to get this mount off? And, what mount will I need at rear of auto trans? Any of you that have already done this, can you lead me through the procedure? Thanks!!
Re: trans cross member information
the top mount rivets can be got to from the bottom of the frame . you should be able to get to the bottom of the rivet with a air hammer pop the head off and push it up . as far as the auto trans mount they come up on here from time to time but their is aftermarket ones available
The Older Generation
The engine was out of the Panel Truck when I took mine out but I still had to get to it from underneath. Broke it down into 3 pieces. Between the angle grinder and the air chisel I was victorious.... ![]() LockDoc
well, I got serious about getting the cross member out today. Only, mine didn't look like the pictures you guys posted. Mine was a disaster, at least in appearance. BUT, I did get it out after hours of cutting, grinding, chiseling. I used every tool in my arsenal and went through most of my cut off disc and Sawzall blades. There were a couple places that you just couldn't get to with a blade. I tried chiseling the heads off the rivets, but the rivets wouldn't drive out, so I started cutting. I will have to go back and clean things up a bit before I let anyone see my results.
I wanted to give a big thank you for the folks that encouraged me and gave me faith that I really could do this! And, best of all no one was injured and nothing on the truck was destroyed in the process. So, all in all, I'll consider it a Success.... |
#5 | |
![]() Join Date: Mar 2011
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Had lots of fun with mine as well earlier this year, all the guidance above was bang on. Glad to hear you won the battle yesterday
1968 Pontiac Firebird purchased in September 1980 1968 Ford F100 purchased in September 1981 1970 C10 purchased in August 2012 1984 Oldsmobile Cutlass purchased in October 1993 1989 Ford Mustang 5.0 LX purchased in 1989 1992 GMC 1500 purchased in October 2020 |
Now that I have the cross member out. Where can I find one after market??
Last edited by LockDoc; 05-12-2020 at 09:59 PM. Reason: Must be a Premium member to post a "Want To Buy" |
I will look tomorrow....but CPP, Summit ,LMC, Brothers Ecklers they all have them
Thanks ZICC1835 for looking for me. I found one locally. Thanks again!!
