Old 05-10-2020, 10:16 PM   #1
ncsurveyor
Help with wheels for my 68 stepside
I’ve got a 68 short stepside and I’m looking at wheels. Im putting 5 lug axles in it and I like the Ridler 695 wheels. I’m gonna have a 4/6 drop and I’m wondering if the 20x10s will work in the back? Looks like they have a 0 offset and 5.5 backspacing.
ncsurveyor is offline   Reply With Quote
Old 05-11-2020, 06:50 AM   #2
jessemthompson
Re: Help with wheels for my 68 stepside
I can tell you that they work on a fleet side. They are the same wheels I run.
jessemthompson is offline   Reply With Quote
Old 05-11-2020, 08:24 AM   #3
Mike C
Mike C's Avatar
I have 17x9.5" on back of my '69 stepside with zero or 5" backspace. Tire is a 275 55 17. I converted to 5 lug and am running the wider '71-'72 rear axle. Clearance inside and out is about the same. My truck is leaf spring with a DJM flip kit that netted 7" drop.
You MIGHT get a 285 55 17 on that without rubbing. The 10" rim might work with a 40 profile or lower tire no wider than 285, but it is going to be TIGHT.
It will absolutely NOT work if you have the earlier, narrow axle. The stepside bed limits tire size drastically compared to a fleet. Now if you are willing to mini'tub the inner bedside you have a lot more clearance. Especially a coil spring truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-11-2020, 09:00 AM   #4
68Stepbed
68Stepbed's Avatar
You'll want a 5" backspace, or run 1/2" spacers with those wheels. You will only be able to fit a 275 tire. 295's will fit, but will rub the inside edge of the bed on corners when the chassis flexes.
EDIT- This information is only good if you have the wider 71-72 axle. If you're only putting 5 lug axles in your current rearend, you'll need a 4.5" backspace, or run 1" wheel adapter style spacers.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-11-2020, 09:32 AM   #5
ncsurveyor
Thanks for the advice guys. So if I go with the 20x8.5 with 4.75 backspace, those should work fine?
Old 05-11-2020, 09:35 AM   #6
ncsurveyor
I'm putting 5 lug axles in the truck, can I just put these longer 31.5" axles in? Will these work?
https://www.performanceonline.com/19...-Bolt-Pattern/
I was planning on ordering these:
Is there a difference other than the length and will the longer ones work with my rear end and allow me to run the 20x10" wheels?
Old 05-11-2020, 09:49 AM   #7
68Stepbed
68Stepbed's Avatar
The longer axles won't work. They're made for the longer axle housing. 1970 was one of those oddball years. Early models had the shorter rearends, and a few later models had the wider rearend. It's kinda weird.
You could still run the 20x10s, but you'll have to run adapter spacers unless you get custom wheels made. It's just the nature of the beast.
Matt
Old 05-11-2020, 09:49 AM   #8
68Stepbed
68Stepbed's Avatar
What are your plans for rear brakes?
Matt
Old 05-11-2020, 10:08 AM   #9
ncsurveyor
I've got this kit picked out or something similar for the rear. Will this work?
https://www.performanceonline.com/71...it-rear-5-lug/
Old 05-11-2020, 10:09 AM   #10
ncsurveyor
I'm pretty new at this and still learning and researching before I order my parts. Gonna try to do the suspension and brakes and new wheels/tires myself, then take it to a shop to do the engine swap. I'm leaning toward an LS1.
Old 05-11-2020, 04:50 PM   #11
68Stepbed
68Stepbed's Avatar
I don't see any reason that kit wouldn't work, but here's another option. https://azproperformance.com/collect...-kit-71-87-c10
They're also pretty good at offering discounts to board members, and members of their Facebook page: C10 Addiction. https://www.facebook.com/groups/7918...epa=SEARCH_BOX
From their page if you're not on FB.
"This is a Pro Performance ran group, and we do offer member discount on most items. Enter coupon code "c10member" on our website. Or call or email us too! 480-420-8175 or sales@azproperformance.com
If messaging, make sure to send directly to the Pro Performance business page. "
Matt
