Old 05-11-2020, 09:01 PM   #1
71K5Randy
71K5Randy's Avatar
Plastic seat belt sleeve/protector questions
I have lots of questions about the yellowish plastic sleeve on the passenger front inner seat belt...
Like were they used on all years 69-72?
Were they used on all belt colors? It seems like I only see them on black belts.
All the sleeves I have seen were heavily yellowed to tan to orange - what color were these originally? Like a translucent off-white such as a natural nylon plastic color? Has anyone ever seen an NOS one or GM stock photos?
Can these be removed from the belts without destroying them, cleaned and reinstalled?
Thanks for any help!
71 K5 CST Blazer 350
70 Suburban 350
71 Chevelle SS 454
69 Olds 442 454 (yes, Chevy power!)
68 Camaro RS 327
66 Chevelle SS 396
Members I have met: 62cdan, 60case, daddymoo2, aotte1, 70shortfleet, countr, Cowboy#40, chevy71super, davischevy
71K5Randy is offline   Reply With Quote
Old 05-11-2020, 09:24 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Plastic seat belt sleeve/protector questions
I believe these started life as clear or non yellow and discolored over time. That in my blazer now is still fairly clear but I have a yellowed example as well. I’ve seen these on parchment and saddle and assume present on all colors. What I’m unsure of is whether or not a matching color boot was also employed like those on the rear seat belts.
Old 05-11-2020, 09:40 PM   #3
71K5Randy
71K5Randy's Avatar
What’s the best/clearest sleeve you have? I’d be interested in pics!
70 Suburban 350
71 Chevelle SS 454
68 Camaro RS 327
66 Chevelle SS 396
Old 05-11-2020, 09:56 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here’s a comparison. The clearest example is more yellowed than I remembered but no where close to the other example. My parchment belts were redone. The saddle belt is all original untouched.
Old 05-13-2020, 02:36 PM   #5
71K5Randy
71K5Randy's Avatar
Has anyone removed the sleeve for cleaning or belt restoration? Which direction does it slide, towards the buckle end? Lube with dish soap or something else?
70 Suburban 350
71 Chevelle SS 454
68 Camaro RS 327
66 Chevelle SS 396
Old 05-13-2020, 04:16 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I believe either the belt or the sleeve would have to be cut for removal.
Old 05-13-2020, 06:58 PM   #7
71K5Randy
71K5Randy's Avatar
I found these pics that show the sleeve moved or loose. It suggests it might be removed by sliding towards the buckle end but I don’t know that for certain. I tried prying on mine with a moderate amount of force and it didn’t show signs of budging.
70 Suburban 350
71 Chevelle SS 454
68 Camaro RS 327
66 Chevelle SS 396
Old 05-13-2020, 08:45 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The sleeve seen in the top photo no longer has a taper at the floor pan end producing a “waist” in the belt so i suspect it is either split or cut. You can see that level of narrowing on your second pic and it sort of seen on my pic.
It’s a no go but I suspect if you pull hard enough you’ll be successful at dislodging the sleeve
Old 05-13-2020, 10:16 PM   #9
1rippen6
I haven't tried it yet but thought some heat to soften it up and then pull. Maybe a tag team effort, someone with a heat gun and another with a pair of gloves ready to pull.
1rippen6 is offline   Reply With Quote
Old 05-14-2020, 05:02 PM   #10
71K5Randy
71K5Randy's Avatar
I successfully separated them last night. Used dish soap and water for lube. Started twisting the bracket and the webbing broke free from the belt. Then the sleeve could be slid towards the buckle end. I removed the buckle and folded the stitched end of the webbing like the pic so I could feed it into the sleeve, and it went through.
70 Suburban 350
71 Chevelle SS 454
68 Camaro RS 327
66 Chevelle SS 396
Old 05-14-2020, 05:05 PM   #11
1rippen6
Awesome!!
Old 05-14-2020, 05:28 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice! I forgot the buckle can be removed. Curious to see if it cleans up. I'd like to clean the darker example I have but nervous to induce a split.
Old 05-14-2020, 10:06 PM   #13
71K5Randy
71K5Randy's Avatar
Mine has one light and one dark side. The dark side definitely feels like it could crack from pressure but the light side still has spring to it. I’m going to first try cleaning it with some dish soap and a brush, and/or maybe simple green or oxiclean.
70 Suburban 350
71 Chevelle SS 454
68 Camaro RS 327
66 Chevelle SS 396
Old 05-19-2020, 07:45 PM   #14
71K5Randy
71K5Randy's Avatar
Next question, what years were short vs long sleeves? My 71 is 5-3/4” long. Pic from 1rippen6 below includes a couple shorter ones, maybe 1” shorter, at least 1 of which is believed to be a 69. Who else has any from 70 that are long or short?
70 Suburban 350
71 Chevelle SS 454
68 Camaro RS 327
66 Chevelle SS 396
Old 05-19-2020, 08:52 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Great pic. I’ve got no clue regarding length. Would be interested in knowing.
