Old 05-12-2020, 09:53 PM   #1
Ryanz
Sway bar bushings
So, I got my hands on a later 70’s sway bar and spring caps from wrecker. Bought new bushings. However, I can’t find anyone in town to push the new ones into place. They’ve been trying with a press but no luck. They’ve phoned around and no one seems to have the tool or machine to do this anymore? Any suggestions?
Ryanz is offline   Reply With Quote
Old 05-13-2020, 12:01 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Sway bar bushings
Are you talking about the ones that go in the ends of the sway bar?
Like here?
I used a 2 piece urethane bushing.
One half in on one side, the other half in through the other side.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-13-2020, 12:15 AM   #3
BobbyK
BobbyK's Avatar
You could freeze the bushings over night then when you go to install...lube the hell out of everything and press them in.
Some reddy rod or large bolt and 2 sockets, one the same size as the bushing and one slightly larger than the orafic the bushing is being pressed into. Thread the reddy rod through the center of everything and tighten away.
"should" press in.
Old 05-13-2020, 12:58 AM   #4
Ryanz
Like here?
Yes - those are the ones. Awesome, thanks for the response. So is there a part number or do I just ask for a 2 piece in this size?
Old 05-13-2020, 12:59 AM   #5
Ryanz
"should" press in.
Interesting - I may have them give this a try before I go to the 2 piece option.
Old 05-13-2020, 07:08 AM   #6
A spring shop can't deal with bushings anymore?
Old 05-13-2020, 10:59 PM   #7
BobbyK
BobbyK's Avatar
I was thinking the same thing when I 1st read this
Anyway this is what I have.
https://www.summitracing.com/search/...eyword=3.5118r
