Old 05-14-2020, 07:50 PM   #1
chewychevy67
Anyone ever used a fuel pipe restrictor in their in cab tank neck?
I was thinking of adding one of these to my 1967 in cab Fuel tank to stop the gas from getting to the cap so easily on left turns and spilling out onto the paint. If I added a few extra small holes so it could breath would this affect the expansion and venting of the gas cap? Anyone ever done this and had problems?
chewychevy67 is offline   Reply With Quote
Old 05-14-2020, 07:57 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Anyone ever used a fuel pipe restrictor in their in cab tank neck?
Sub’d
Tyler
Old 05-14-2020, 08:36 PM   #3
truckster
truckster's Avatar
You don't need to add any holes, as it's not going to seal tightly enough to keep vapor from escaping. But for the same reason I'm not sure it would do a lot of good. It might help some with surges of gas.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 05-14-2020, 08:50 PM   #4
chewychevy67
I just thought if there wasn't a Rush of fuel the full size of the pipe and a by only a quarter of the size of the pipe I would have a better chance of it not reaching the cap.
Old 05-14-2020, 08:55 PM   #5
Astro-Balls
Astro-Balls's Avatar
I have one in my 1971 Ranchero, it works well.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 05-14-2020, 11:54 PM   #6
rockyrivermark
$350 for Performance online aluminum 19 gallon baffled tank under the bed solved these problems.
Safer also.
IMO
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 05-15-2020, 04:31 AM   #7
chewychevy67
Keeping it original so moving the tank is not an option
Old 05-15-2020, 06:14 AM   #8
rpmerf
rpmerf's Avatar
Where did you find this?
There was a thread recently that suggested a quality cap, or modifying the currently cap should keep it from spilling.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 05-15-2020, 09:13 AM   #9
chewychevy67
https://www.fillernecksupply.com/unl...h-filler-pipe/
Old 05-15-2020, 10:21 AM   #10
bigmac73
bigmac73's Avatar
My question is how the heck would u get it in the neck with out destroying the weld seems
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 05-15-2020, 10:24 AM   #11
chewychevy67
The top is just soldered on. Just remove it, slide this down the pipe, and resolder the top on.
Old 05-15-2020, 12:03 PM   #12
54blackhornet
54blackhornet's Avatar
Did you think about not filling the tank so much ? I never had this issue.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 05-15-2020, 04:34 PM   #13
chewychevy67
I haven't either. In fact I have never even put gas into it yet. It's my build. I just am trying to eliminate problems other ppl have had while my tank is new. I don't overfill tanks. That's done for expansion but I hate stains on my paint. Storing it with a half empty tank can lead to rust problems down the road.
Old 05-16-2020, 09:02 AM   #14
BT71
Not sure if this helps,but when recently pulling my rusty ‘69 tank, I had a spare ‘72 tank. During rinsing of the ‘72, I found that I couldn’t pour a couple of gallons out of it through the filler neck, it had to exit through the sending unit hole. The ‘72 filler neck protruded into the tank by several inches, whereas the ‘69 didn’t. Seems like this would alleviate slosh getting to the cap.
BT71 is offline   Reply With Quote
Old 05-16-2020, 11:38 AM   #15
binford
Run an old fashion gas non locking, twist on gas cap.
I remember filling up and going around a corner and watching the gas just pour out. I found the rubber seal was not working.
Switch to a stock cap problem solved.
binford is offline   Reply With Quote
Old 05-17-2020, 12:30 AM   #16
chewychevy67
This is the locking cap I intend to use. It is an original not a repo. It is a spin on type and it does seal fairly tight with a new cork style gasket. Maby I'll just leave it and we'll see. If it leaks I'll get a different cap.
Old 05-17-2020, 05:48 PM   #17
Astro-Balls
Is there a good aftermarket "Original Style" Cap?
Old 05-17-2020, 05:56 PM   #18
72c20customcamper
72c20customcamper's Avatar
I've never had gas come out of the cap while turning on either my 68 or 72.
Not being a smartass but it's never been an issue for me
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
